Old 05-04-2014, 06:20 PM   #1
acpstunts
acpstunts is an unknown quantity at this point
2001 BMW 330ci Drift Ready (CNJ)
Price Drop
$6500.00 with OEM wheels
+$2800.00 If you want the CCW's (Or will sell alone)
This is for a BMW 330ci 186xxx miles.5spd. Burns ZERO oil. Maintained like any car lover would. ALL Service records from myself and previous owner ( HUGE pile of documentation for everything done to this vehicle). I purchased this vehicle at 70k. Previous owner had almost all work done at BMW dealership. I personally racked up tons of highway miles commuting to/from Poughkeepsie, NY and a few trip to Ocean City, MD. Otherwise this car stayed local. Has been to, two events (one on track, one in parking lot) Otherwise this car has been babied.
I am moving to Florida later this year and would like to get it into the hands of another good owner who will take care of this car, so i can start a new project down there.
NOT looking for trades. CASH ONLY.
-18" CCW Classics (Race spec but street version with neochrome ARP Bolts and custom waterfall & Swissed faces) These are 18x9 ET24 Fronts and 18x11 ET 22 Rears (one of a kind). Front tires are fairly new Federal 595's the rears (need replacing soon) are Ecsta XS Racing Compound Tires.
-OEM M68 Wheels
-Lug/Stud Conversion with Muteki Burning blue extended lug nuts
-Full Custom SLR Adjustable Control Arms (with all spherical and solid bushings) These adjusted out can give you some insane steering angle. (Same setup Chelsea Denofa Runs on his e46)
-BC Racing Coilovers 32 way adj. 8k Fronts 12k Rears (with front and rear BMW reinforcment plates)
-Mason Engineering Sphericle Sway bar Endlinks (Front)
-UUC Front and Rear Sway Bars (with red polly bushings)
-Mason Engineering Rear Subframe Reinforcment Brace
-Velocity Motorcars Rear Adjustable Arms
-UUC Red Transmission Bushings (also will include oem Bushings)
-OEM BMW Performance Cross Drilled Semi Floating Front Rotors / UUC Slotted Rear Rotors with Hawk HPS pads all around.
-M3 Front Bumper with Busted Front Lip
-M3 Side Mirrors
-Momo Steering with with NRG 2.5 Quick Release and Momo shrt hub.
-CSL Full Carbon Fiber Trunk
-3.46 Welded Rear Differential
-Depo Project Headlights. 6k Hid headlights with Preditor Orion V2 Angel Eyes (Clear sidemarkers and side lamps) (Lamin-X Film over headlight lenses Immediately installed when purchased. 0 Lense Imperfections)
-Clear/Red LED Tail lights
-LED License Plate Bulbs
-Dynavin Double din Headunit with Navi, bluetooth, ipod, cd, dvd, etc.
-Prosport Gauges ( Oil pressure, Temp, and coolant temp ) Also have installed volt meter.
-ECS Tuning Aluminum Waterpump pulley, K&N intake filter with RPI Ram Air scoops
-Oil Catch Can Installed
-Quick Release's installed for front and rear bumpers.
-New Radiator and expansion tank installed.
-All Red Line Fluids (Diff, trans)
-"Drift Button" Installed on the oem ebrake.
-Oil Changed every 5-7k with OEM BMW Filter / BMW Castrol.
-Windows are tinted 5% back window/ back side windows. Front side windows and windshield is tinted 35%
-Brand NEW Alternator installed.
-Rebuilt DISA. New Spark Plugs (NGKs) New Parking Brake Pads installed. New Serpintine Belt.
-Fuel Pump Replaced 10k miles ago. Along with fuel filter.
-K&N Air Filter. New Intake boots
-Oil Filter housing gasket replaced.
The cars interior for the most part is out. It does come with the OEM Black Leather Seats which include Heated, Lumbar, Power, fully adj. Also the Dash is all Black as well.
I know im forgetting tons of things. this car doesnt really need anything. Only thing it could use is a muffler/extended pipes (will include oem one thats not attached). I cut off the prior muffler in expectations of running the straight pipe out the side or back. Just never got to it.
Also the car was slightly clipped on the back left. Frame is 100% straight just the bumper there is a bit warped and there is a slight crack in the taillight housing. The check engine light is on ONLY because for me to run the oil pressure gauge, i tapped into the factory oil pressure sensor , but in doing so had to not hook back up the oem pressure warning wire (which would alert you on the dash if your oil pressure is low) but the gauge i have installed does the same. I have TONS more pics showing almost all the progress. Again serious inquires only.
I also have brand new in box:
- Chelsea Denofa Fender Flares (same ones he runs on his Drift BMW and can only be bought through him. I had to wait almost a year to get these since they are real limited) -$350.00
acpstunts is offline   Reply With Quote
Old 05-04-2014, 07:09 PM   #2
Got Insulin?
Got Insulin?'s Avatar
Got Insulin? is an unknown quantity at this point
And last but not least, a friendly reminder that external links to other for sale pages are not authorized:
eBay
Craigslist
other car forums.
Just of note from the rules...
Got Insulin? is offline   Reply With Quote
Old 05-04-2014, 07:35 PM   #3
acpstunts
Sorry about that. Will fix it now Thanks!
Old 05-06-2014, 07:32 PM   #4
1jz s14 zenki
1jz s14 zenki is an unknown quantity at this point
I got a 1jz s14
text me 609 240 4757
1jz s14 zenki is offline   Reply With Quote
Old 05-07-2014, 07:19 AM   #5
acpstunts
Unfortunately I am not looking for trades. Have to drop the car thing for a bit until i get settled down in FL. But thanks though
