Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 05-27-2014, 12:19 AM   #1
JBtuned
JBtuned's Avatar
JBtuned is an unknown quantity at this point
Surge Tank - Dual Bosch 044 Surge Tank @ JBtuned.com
Bosch 044 Dual or Single Pump Surge Tank @ JBtuned.com
These tanks are designed for use of twin Bosch 044 Fuel pumps. The tank can also take advantage of one pump with the optional cover.
You are given a choice of outlet fitting size.
Here is the basic product desciption and more can be found here.
Basic Information
The Aluminum Bosch 044 surge tank works inline with your current fuel system. The surge tank fills up with fuel from the OEM in tank pump. The Bosch 044 Fuel Pumps inside the surge tank draws from this reservoir providing a constant flow. Fuel is only returned to the main tank when the surge tank is 100% full, thus providing a steady supply of fuel. Our Bosch 044 Duel pump surge tank solution far exceeds the engineering found in traditional surge tanks, outperforms externally mounted fuel pumps.
The Aluminum Fuel Surge tank houses two Bosch "044" pumps and keeps them submerged over 75% inside the tank. Using the fuel to submerge the pumps will muffle the noisy pumps, provide cooler pump operating temperatures for longer life, and ensure the pumps will have fuel even on steep turns or accelerations where the OEM pump could experience fuel starvation. This surge tank setup is for high powered vehicles and is rated up to 1200BHP.
Anti-Corrosive Military Grade Anodizing
Running E85, methanol, C16 or any other type of race gas? The aluminum of our surge tanks comes standard with military grade anodizing inside and out to prevent corrosion and preserve the life of your investment. This anodizing comes standard on our surge tanks and is not an additional option. No need to pay extra for something that a quality tank should have standard!
SPL Parts | BC Racing | Nismotronic | AEM | Grip Royal | Comp Clutch
JBtuned is offline
Old 05-27-2014, 10:56 AM   #2
slider2828
slider2828's Avatar
Great product! Unfortunately its a copy from integrated engineering who came up with the solution......
Turn and Burn!
slider2828 is offline
Old 05-27-2014, 12:07 PM   #3
JBtuned
JBtuned's Avatar
Thanks.
Our Solution when we set out to create this surge tanks was to not recreate the wheel. A basic aluminum box that holds enough fuel for one or two Bosch pumps. The tank comes with a mounting bracket and log manifold. Simple design and easy to setup.
The difference with our tank design is we make it affordable. I wanted a quality tank that will last and the average person could afford.
We decided not to nickel and dime for little things like, anodizing the insides of the tanks to protect the aluminum from fuels like E85 or C16. We don't powder coat the tanks, they are 100% anodized. We don't charge extra for the log manifold or the inlet/outlet fittings. All our tanks come complete and they ship for free.
JBtuned is offline
Old 05-27-2014, 03:22 PM   #4
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Whats the install consist of? And its engine bay mounted?
Luvs2slide is offline
Old 05-27-2014, 04:09 PM   #5
JBtuned
JBtuned's Avatar
The tank has to be mounted with pumps facing up but location is up to you.
Install:
The tank has 3 fitting on the top of the tank.
1 is used as a feed from your factory fuel tank/pump.(fuel into tank)
1 is used for the return from your fuel pressure regulator.(fuel into tank)
1 is used as a return back into your factory fuel tank.(fuel out of tank if it gets to full)
It does not matter which fitting on the tank you use for either feed or drain as long as those are plumbed up.
Then the log manifold goes to your rail or rails.
Hope this helps.
JBtuned is offline
Old 05-27-2014, 07:22 PM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
So why twin Bosch pumps? Is one pump inside the surge tank not sufficient?
brndck is offline
Old 05-27-2014, 07:46 PM   #7
JBtuned
JBtuned's Avatar
It can be. That's why we offer the block off plate for those who only want one pump.
Its really depends on your build plans and how much fuel your going to require.
JBtuned is offline
Old 05-28-2014, 08:25 AM   #8
boback1
boback1 is an unknown quantity at this point
pm me a price for the surge tank with and without the dual pumps.i don't need the log adapter for the pumps I run dual -6an feed lines.shipped to 77043 thanks.
boback1 is offline
Old 05-28-2014, 08:00 PM   #9
JBtuned
JBtuned's Avatar
Pm has been sent.
JBtuned is offline
Old 06-01-2014, 12:19 PM   #10
SPATURBODAVE
SPATURBODAVE's Avatar
SPATURBODAVE is an unknown quantity at this point
Originally Posted by JBtuned View Post
Pm has been sent.
Shipping is free correct?? Quote me with the two )44's and the block off plate... What is the volume of the tank with the two 044's installed ?
SPATURBODAVE is offline
Old 06-09-2014, 05:32 PM   #11
JBtuned
JBtuned's Avatar
PM has been sent
JBtuned is offline
Old 06-09-2014, 05:33 PM   #12
JBtuned
JBtuned's Avatar
Please PM us with any questions you may have. or visit us on www.JBtuned.com
JBtuned is offline
bosch 044, e85, fuel delivery, fuel pump, surge tank
