Old 06-12-2014, 10:35 PM   #1
bmx2day
bmx2day is an unknown quantity at this point
1993 240sx Silvia Hatch
93 240sx Hatchback around 170k on chassis the car has been approved for 2014 Vegas Proam series tech inspection.
Exterior
Rusted patina ratrod look, just surface rust that can be sanded off if not wanted to paint the car.
Silvia front with carbonfiber hood, missing grill and bumper.
Front bash bar.
5 lug.
(6) 17x9 et17 wheels.
2 brand new Federals on the spares.
Will include another pair of tires for front wheels also. (Almost done Federal RSRs on the front now)
(4) 25mm wheel spacers.
Tow strap points front and rear.
Interior
6 point roll cage to proam spec.
Full painless wiring setup Moroso switch panel with push button start. NO KEY to start. Removable hood cowl cutoff switch key.
Momo drivers seat.
TAKATA drivers 5 point Harness.
Grip Royal wheel.
Knockoff Nismo shift knob.
Freshly painted oem Nissan white on the interior including the cage.
SFI Approved rollcage padding.
Relocated battery with rear in cabin cutoff switch.
Fire extinguisher.
Suspension
Ksports coilovers.
Soild Aluminum rear subframe bushings.
Aftermarket rear arms.
Future Fab angle knuckles.
Boxed and extended Lcas.
Tein inner and outer tierods.
Steering rack spacer.
All other bushings upgraded to Energy poly.
Welded rear end.
Engine
Sr20det Redtop all original longblock
T25 @ 11psi with Greddy Prof 2 electronic boost controller.
BWR Aluminum radiator.
ACT Clutch.
Silicone hose kit.
Ford Taurus fan over 4000cfm
Greddy type rz BOV
Greddy FMI.
Greddy intercooler piping.
Isis exhaust manifold.
Isis 3 in exhaust.
Isis turbo elbow.
Aluminum overflow container.
Aluminum catch can.
AN Turbo lines
AN Power steering setup.
Solid motor mounts.
Nismo transmission mount.
Walbro fuel pump.
The car had always been good to me and was built to be driven with no regrets. The chassis is solid and ready to be drifted the day you get it. Car was prepared for the last drift event that was canceled and ready togo. Sorry for any typos and I'm sure I'm missing alot. Price is $5,500 firm.
text for best response 602 384 4862
bmx2day is offline   Reply With Quote
