Old 06-14-2014, 10:30 PM   #1
h815 240sx
h815 240sx is an unknown quantity at this point
93' s13 hatchback w/ 1JZ
NEW PRICING GUIDE
$10,000 - Will have brand new front bump
$9,500 - No front bumper non painted side skirts
$8,700 - No RaceTech seat and no Nagisa seat rails
$7,900 - $7,700 No Teamtech harness(es) and No Autopower cage
$7,500 No OMP steering wheel
*All prices include the previous mentioned parts in addition to the new ones
** Will only trade for FD cash on my end
Nothing will be touch on the suspension or performance side. If you choose the last option, a stock seat, 2 stock seat belts and a steering wheel will be provided in the purchase.
The car
Car was originally from Florida, so it is a rust free chassis. I've had it for three years now and its always been garage kept. There was about 100K on the chassis when I got it. Unknown milage on the 1jz, but I did pull the head and check the valves and vales seals and everything was good.
All suspension and chassis parts have less then 5k miles on them
All engine and transmission parts that were replaced have less then 2K miles on them
Please feel free to ask questions and contact me.
-Aero-
Version Select 5 side skirts
Origin Stylish rear bumper
Dmax Pole Position lights
Just painted last season in Chrysler PBJ, its off the Ram 1500
Aerocatch hood pins
Front bumper to be discussed on inquiry
-Brakes-
Oem S13 calipers
Brembo OEM front rotors
Brembo OEM rear rotors
Hawk Hp+ front pads
Prodject Mu D1Spec rear pads
OEM s14 5 lug hubs up front
New Rear wheel bearings
-Wheels-
(2) Blitz 03 17x9 + 15 w/spacers
215-40-17 Federal Evo 595
(2) Blitz 03 17x10 + 25 w/spacer
(2) Mustang Cobra Reps 17x9 +20
-Steering / Suspension-
Stance Gr+
Peak Performance Inner Tie rods
S14 outer tie rods
S14 knuckles
S14 lower control arms
Peak Performance Tension Rods
Peak Performance Toe Rods
Peak Performance Ruca's
Boxed the tension rod brackets
New Power Steering rack
Chase bays power steering reservior
Chase bays high and low pressure power steering lines
Power By Max rear subframe spacers
- Engine -
Engine came from Zero Lift with unknown miles.
New Engine gasket kit
New Valve cover gasket
New hydraulic belt tensioner
New Greddy timing belt
New ARP head studs
New thermostat
New water pump
New aluminum pulleys
New Gates serpentine belt tensioner
New throttle position sensor
New coil pack connectors
New 3" y pipes
New 7mgte starter
New Engine/ transmission) mounts (engine mounts work fine but transmission was a joke. I had to remake the bracket to account for drive line phasing. Center line of the yolk should be down 1 degree but no more the. 3 degrees and there mount was down 11 degrees. This doest allow the joins of the driveshaft to work properly.
New nismo motor mounts
-Transmission-
New ARP fly wheel bolts
New ACT heavy duty clutch 6 puck sprung
New Driftmotion light weight flywheel
New clutch cylinder
New clutch release hub
New custom 1 piece steel driveshaft from the DriveshaftShop
-Other Engine Related Items-
Aeromotive fuel pressure regulator with lines
Powered by Max high mount intercooler
intercooler piping, tbolt clamps and couplers
Mishimoto SR radiator with hoses
two Spal pull fans
New brake master cylinder
Tubbed front fenders
-Interior-
Full interior
Auto power 4 point cage with monkey bar
Passenger team tech harness
Drivers Team Tech harness
Drivers seat is a Race Tech
Drivers seat rail are Nagisa dual locking
Passenger is oem seat
Omp 330mm Corsica wheel
Works bell short hub
Push button start
Aftermarket head unit
-Custom gauge cluster-
Stack tach
Stack oil pressure
Stack water temp
Stack fuel level
Auto meter boost gauge
Just showing how few miles are really on the car.
Coilovers are 4 years old and look almost brand new still.
Forgot to add the Gauge Cluster
and a picture of the engine bay
h815 240sx is offline   Reply With Quote
Old 06-15-2014, 12:01 AM   #2
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
wowowow i want this. sick. free bump
vJilly is offline   Reply With Quote
Old 06-15-2014, 11:43 AM   #3
h815 240sx
edit edit edit
Old 06-17-2014, 01:31 PM   #4
h815 240sx
Afternoon bump to the top
Old 06-17-2014, 02:22 PM   #5
Ekaptn
Ekaptn is an unknown quantity at this point
bump, very clean. hope you get what you want. gl
Ekaptn is offline   Reply With Quote
Old 06-17-2014, 03:00 PM   #6
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
looking good man
Old 06-19-2014, 02:10 PM   #7
h815 240sx
Last pump. I'll have a new thread in a couple of days with a new pricing set up that you all might find interesting.
Old 06-20-2014, 08:21 AM   #8
h815 240sx
Mods please lock so i can start a new thread in the 3 days waiting time
