Old 06-17-2014, 01:08 AM   #1
zeebrah
zeebrah is an unknown quantity at this point
Exclamation UPDATED:TONS of parts..Turbo..Boost Controllers..Injectors..Drifting...SOHC + more!!
UPDATED! Added items and cleaned up version of old thread....
Time for some much needed cleaning and extra cash for new motor build!
**WILLING TO TRADE + CASH MY END FOR: FAB WORK, BLOCK/ HEAD BUILDING, THRASH RACING SEATS, s13 window switchs (dont need to work)!! or if you can flat out offer any of this pllllease contact me****
Due to work for fastest reply PLEASE TEXT 714 305 4895 ANYTIME.. or call an leave message might not answer and will try to check PMs often. I know pictures suck on somethings so please feel free to ask for better pictures via text. WILLING TO SHIP...
Have tons of crap laying around if dont see just ask
READ BETWEEN PICS I HAVE MANY ITEMS POSTED WITHOUT PICS
Boring but good:
-ka clutch interlock switch basically new just dirty $20. tried everything and your shit still dont start or hadstart some days? this IS your problem.
-s13 interior gas/truck latch $15
-s13 hood latch cable $10
-stock s13 rear upper control arms. not bent w/ good bushings $10
-stock s13 rear tor arms. not bent w/ good bushings $10
-open diff. just diff! no pumpkin..Clean/good condition. ready to weld $25
-Misc length and shape 2.75" aluminum intercooler pipes $depends
-about 2.5' battery ground cable with terminal and bolt down end $8
+a bunch of random interior trim and pieces....random wiring JUST ASK IF LOOKING FOR ANYTHING
-About 2 sohc motors for part out. i am keeping one block, head, valve cover and intake mani
sorry motor pics suck
-NGK spark plug wires for sohc. full set. under 100 miles just dirty. some heat wrap on 2 $15
-Second set of NGK sohc plug wires. Full heat wrapped (look same as picture above just fully wrapped and cleaner) and under 100 miles as well. Boot to plug 3 broke off. please inquire for pics $10
-Volvo lip. dunno what exactly it came off buuut they mod and put these on just about everything. great condition no cracks etc.. just muddy and dirty in pic. $15
INJECTORS
-2x sets of 4 SOHC injectors. all working when pulled $15 a set. we know what they look like..
-52lb precision/msd high imp top feed injectors. Last owner said they were reflowed by RC but i have no proof but whatever they work $95
INTERESTING SHIT:
-FULL SOHC TURBO KIT inquire* or search my zilvia name and look up posted thread!!!
-Holset HE351VE VGT Turbo. These turbos are not as well known in the 240 world but have been proven on other chassis. Google up and you will see this is the future of turbos. Spool fast like a small turbo but kick like a hx40... This particular turbo has been moded to have vanes closed till 11ish psi then open untill desired boost level. Electronics have been removed (now no need for coolant) and boost is now controlled via a hard mounted wastegate. Total boost is regulated by a second external wastegate. Can controll when vanes open with inline boost controller. Bit difficult to wrap your head around at first but feel free to ask any questions. Simply put...spool 11psi before 3k and hit 30+psi by 4.5k. V-band exhaust outlet... compressor housing, center and exhaust turbine all v-banded. Also this thing sounds like NOTHING else youve ever heard. Be a man. Be a badass. Be original....probably killing yourself in the process. Turbo has no shaft play and rebuilt with genuine holset parts. Will come with assorted stainless lines for oil feed, drain and vacuum AND BRAND NEW VGT FLANGE to weld to your mani... $700
For size comparison (angles mess up pic a bit)
-Apexi AVC-R BLACK Edition. Electronic Boost controller. Complete and in great condition. W/ Apexi mount. small scratches on lower left of screen $390
-HKS *authentic* Air filter. 3" inlet. Has chip on neck...covered and works perfect without leak once covered with coupler... $55
-TOP FUEL 'special dragon street fighter' catback exhaust. THE BEST GODDAMN EXHAUST EVER MADE. And best goddamn name ever. Search and find talk about how wicked this thing sounds. Pretty firm on price as i love this piece. Unfortunately i dirt dropped at track pretty hard and cracked resonator. took pics should be reweldable or cut and replace with straight pipe. easy job for any shop. Resonator was dented before dirt drop and did not affect performance/sound should you choose to go the reweld route $180
-Oil cooler. 'it works'.. easy in out rubber line install. Could use new paint to look good. but gets its job done. mounts perfect for side mount of aero.. $20
-Wastegate elbow. basic 2-bolt 38mm. makes clearance for shit and turns wastegate 90degress $5
-42" led lightbar with mounts. Bright as shit. Two leds dont work. Apparently easy fix but i never bothered. Under hour of use. Canyon/ Zombie apocalypse ready $210
-Takata Rep. 4pt Harnesses with cam lock 3" wide. In great condition. Have 1 left. $55
-Exedy Stage 1 / stage 2 clutch for KA. Stage 1 pressure plate with stage 2 disc. Pressure plate painted ricer blue. Used but pleceny of life left. text for pics or will possibly update $80
-Walbro 255 in tank with s13 wiring (universal if dont need wiring) $60
350z Stuff
-Killer Bee Coilovers. Will lay frame and then some but i ran at normal person height. THE most comfy coils ive ever been on but stiff when you need it. Still on car in good shape. request pics please $800
-Brand new spc rear camber arms and toe bolts.. $95 google pics. Theyre still new in wrapping
-Nismo style rear wing. Was prepped for paint but been sitting awhile. Could rig onto schassis..looks dope on s13 hatch... $90
actual
painted example
-SUPER OFFICIAL TRACK NOTES. $980 FIRM
Braaap
zeebrah is offline   Reply With Quote
apexi, boost controller, holset, turbo
