Old 06-17-2014, 02:28 AM   #1
zeebrah
zeebrah is an unknown quantity at this point
Exclamation COMPLETE KA24E SOHC Turbo Kit! Top mount..Turbo smart..Blow Thru...Z32 MAF..Injectors
Up for sale I have a basically complete turbo kit for a Ka24e
Please contact at 714 305 4895 and feel free to ask any questions!
As of now wold prefer to sell as kit. potential part out if lost of interest in parts...
This is NOT your entry level needing extensive modification china brand kit.
This was a very proven kit making awesome power and very user friendly. People NEVER believed i had a SOHC under the hood. Meanest sounding 240sx let alone SOHC out there. Blow some minds and blow some loads.
CAN work on dual cam ka24de with different manifold and some modding the intercooler piping (ill include extra)
What is included:
-CX Racing top mount manifold. Bracing on wastegate flange and between runners...used and with out cracks guess i got a 'good one'. Wrapped in titanium heat wrap
-Turbosmart ultra-gate 38 38mm wastegate with 9psi?? spring. Comes with orig. box with extra flange for dumb tube or mani. and spanner for disassembling the wastegate
-Custom dump tube that exits out hood with titanium heat wrap
-CX Racing t3o4e hybrid turbo. Some shaft play. I would recommend upgrading in the future. But still boosts hard.
-Oil drain fitting
-Oil feed restrictor
-90deg AN oil feed fitting with long stainless line and T-fitting to block with port for stock oil pressure sensor
-2.5" to 2.75" alum intercooler piping. (Some modding as with any turbo kit... will be necessary to your chassis) with Greddy BOV style flange. Comes with greddy to HKS style flange adapter. Pipe before throttle body has a port drilled for meth injection. will need to be plugged or can supply new pipe to cut to size.
-Authentic TurboXS RFL BOV shimmed to hold more boost pressure without leak. Sounds gnarly.
-OEM Z32 Maf with pigtail. (no reman. or knock off bs here) Ran in blow through configuration. With adapter for IC piping. Run a BOV with out your car running like shit. Get easier tuning. Will run like a non-turbo car if ever blow off a coupler or pipe instead of being stuck dead in the road. ALL AROUND BETTER AND UNDER RATED.
-Large front mount bar and plate intercooler
-ALL couplers and t bolts needed to complete install
-Downpipe with extra port welded for wideband use.
-460cc plug and play injectors
-Walbro 255L fuel pump with wiring
-Z32 fuel filter
-BK7RE NGK spark plugs. Two step colder for turbo use
-will have all assorted gaskets for mani to turbo, turbo to exhaust, oil feed/drain ETC...
-spare ic piping
+sure im forgetting more!
$950.
This is everything needed to turbo your single cam. Alot of work and time and MONEY went into this kit. Ive just come to the point where i need to put some hobbies on hold.
Also have about 2 sohc disassembled forsale or parts.
All items in great condition and worker order. IC and piping has been sitting and dirty will polish up niecly
NOT ALL PARTS INCLUDED SHOWN IN PIC
Braaap
zeebrah is offline   Reply With Quote
ka24e, sohc, turbo, turbosmart
