Old 07-01-2004, 10:19 AM   #1
justinhustle
justinhustle's Avatar
justinhustle will become famous soon enoughjustinhustle will become famous soon enoughjustinhustle will become famous soon enoughjustinhustle will become famous soon enoughjustinhustle will become famous soon enough
5 lug swappage!
when you s14 guys swap to 5 lug, did you get front hubs only or hubs and spindles?
im about to swap out project heaven's front hubs and i didnt know if it needs the spindles as well
thanks
justinhustle is offline   Reply With Quote
Old 07-01-2004, 10:21 AM   #2
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
thanks
you only need to swap the hubs. you only need to use the spindles when installing them on s13
New Video
Buy my mounts!
Old 07-01-2004, 10:37 AM   #3
justinhustle
i forgot to add
are they side specific? and if i get one with spindles on it, can i remove the spindle, or should i just swap the whole unit?
Old 07-01-2004, 10:52 AM   #4
Levi@GTPRO
Levi@GTPRO's Avatar
Levi@GTPRO is an unknown quantity at this point
Send a message via AIM to Levi@GTPRO
Just remove the hub from the spindle. Its alot less work involved. To swap spindle's your gonna have to seperate the spindle from the ball joint on the control arm and tie rod. When you do that your gonna end up destroying them making you have to buy new ball joints and tie rod ends as well as have them pressed out and in. To much work. As far as side specific i dont believe they are.
VisitGTPRO!
This post has been brought to you by LAND HO the fresh makers!
Levi@GTPRO is offline   Reply With Quote
