Old 07-10-2014, 08:55 PM   #1
Mac Nibbles
Mac Nibbles's Avatar
Mac Nibbles is an unknown quantity at this point
Transmission differentiation
So I recently (stupidly) purchased a ka transmission without any sensors. I know there's a difference between the s13 ka dual and single cam transmissions, particularly the gear for the speed sensor. I know for sure I don't have a s14 transmission because there's no hole for the crank angle sensor. So my question is, how do I identify and tell the difference between the two types of s13 transmissions so I don't mistakenly cram the wrong speed sensor gear in there?
Mac Nibbles is offline   Reply With Quote
Old 07-10-2014, 09:57 PM   #2
Agamemnon
Agamemnon's Avatar
All S13 manual speed sensors are the same.
Old 07-10-2014, 10:33 PM   #3
Mac Nibbles
Apparently there are two possible different speed sensor pinion gears for the s13:
http://forums.nicoclub.com/240sx-spe...l-t393740.html
Found some mixed info in this thread too:
http://forums.nicoclub.com/differenc...s-t283066.html
So some clarification would be appreciated
Old 07-12-2014, 01:04 AM   #4
Agamemnon
Agamemnon's Avatar
The difference is that the one came with a 20 tooth pinion, and the "Sport pack" came with a 21 tooth pinion. The 21 tooth pinion was used to correct the speedometer due to changes in the diff gearing for faster acceleration. What diff are you using? If you have a lower geared diff or swapped in a JDM 180sx diff(4.36 ratio), then use the 12T pinion.
Really all you get is a 2-4mph difference in the speedo.
