Old 08-06-2014, 12:52 PM   #1
Atill93
Atill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-knownAtill93 is making his/her stupidity well-known
S13 steering modifications
I've realized that I probably don't need to modify my knuckles and extend my front lower control arms unless I am getting extremely competitive and want every last possible degree of steering angle.
I wanted to verify that all I really need for a fun street setup could be tie rod spacers, s14 front lower control arms (which i already have installed), and upgraded tie rods
i saw another post where tie rod spacers took the steering angle from 31 degrees (stock) to 50+ degrees
do i need extended/upgraded inner AND outer tie rods?
do i only need the tie rod spacers or do the tie rods have to be upgraded as well?
thanks
Atill93 is offline   Reply With Quote
Old 08-06-2014, 03:36 PM   #2
jr_ss
You most likely will need to at the very least have adjustable outer tie rods when trying to get max camber.
Old 08-26-2014, 02:01 PM   #3
Atill93
can any one else verify:
if i get the pbm tie rod spacers
what other modifications will i have to do to get my alignment corrected and a decent increase in steering angle?
Old 09-05-2014, 02:08 AM   #4
badass8
badass8 is an unknown quantity at this point
Bolt on spacer on passenger side and call it a day. Safer and more travel for your steering rack=more angle.
Lexus V8 Into S13 Build
badass8 is offline   Reply With Quote
