Old 08-09-2014, 12:52 AM   #1
Willie fisterbottom
Willie fisterbottom is an unknown quantity at this point
RB25 300zx 5speed problem
Seems as though I have a problem with the internal rail in my 300zx turbo trans behind my RB. I can't get 2, 4, or Reverse...... Anyone ever had this problem?
Willie fisterbottom is offline   Reply With Quote
Old 08-09-2014, 10:19 AM   #2
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Is your shifter hitting the gate under the shifter plate? Seen it a few times with aftermarket short shifters
Edit: just realized it's a z trans tail shaft....get somebody to shift while your under the car and look to see if the linkage is binding on your shifter bracket
Memberofthe600hpkaclub is offline   Reply With Quote
Old 08-09-2014, 10:29 AM   #3
Willie fisterbottom
It has an internal rail system..... i pulled the shifter and housing out that all is fine the "cup" that the sifter sits in looks fine..... Just can't push the rail forward.
Old 08-11-2014, 07:31 PM   #4
Willie fisterbottom
No one has any additional input?
Old 08-11-2014, 07:56 PM   #5
If it's sitting on the ground pull the bellhousing off and make sure nothing is off....did you put that (metal ball bearing thing)?? Back In when you swapped bellhousings?
Old 08-12-2014, 05:06 PM   #6
Willie fisterbottom
The car has been swapped for years..... i bought it from a buddy about 3 months ago. I'll be pulling the trans tonight.
Old 08-12-2014, 09:37 PM   #7
Willie fisterbottom
The problem was where the shift fork comes through the front section of the trans (bell housing) there is a thick metal washer that is a shift shaft stop and it is held on by a snapring, well the snapring came off and the thick metal washer was between the case and the shift shaft. Since it was easy to remove the trans and pull the front cover in the bell housing I'm going to reinstall the snapring and give it another shot if it pops off again I'll have to tack it.
