Old 07-08-2004, 09:42 AM   #1
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
wheel specs for flares
i have 25mm front flares and 30mm rears what wheel width and offset should i use to get them flush planning on a 15in rim but will move up if i need to
all suggestions welcome this is for my s13 coupe
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 07-08-2004, 10:49 AM   #2
TheTimanator
TheTimanator's Avatar
depends on how wide a rim you want to go with...
Old 07-08-2004, 10:59 AM   #3
the head
the head's Avatar
my thought was 7s up front and 9s in the rear
Old 07-08-2004, 01:06 PM   #4
xVaporx
xVaporx is an unknown quantity at this point
I'd go 9's at least front and rear, 16 or 17in. You can go 10' in the rear with over fenders such as your no problem. Offsets, depends. How much camber do you want to run? Whats the intent?
xVaporx is offline   Reply With Quote
Old 07-09-2004, 12:53 PM   #5
the head
the head's Avatar
car will be primarily street and road racing focused planning on using custom made kodiac wheels just deciding what i will need how big of rims do you need for 300zx brakes? IIRC it is a 16 in minimum
Old 07-10-2004, 12:36 AM   #6
Levi@GTPRO
Levi@GTPRO's Avatar
Levi@GTPRO is an unknown quantity at this point
Send a message via AIM to Levi@GTPRO
If you are going to use a 16" wheel make sure the front wheel has a high pad to clear the Z brakes. That or use a big ass spacer.
VisitGTPRO!
This post has been brought to you by LAND HO the fresh makers!
Levi@GTPRO is offline   Reply With Quote
