Old 07-08-2004, 10:32 AM   #1
S14Speed997
S14Speed997's Avatar
S14Speed997 is an unknown quantity at this point
Shaking when start-up, any thoughts?
Okay, this just started this week....
On Monday, and this morning, when i started up the car, rpm's went to about 1300 (which is normal for my car when cold) at the same time it started shaking like it was having a seizure..I turned the car off, back on, and it shook for about 10 seconds, then idled fine....I got out of the car, and smelled gas in the air....??
I moved into a house with a garage, and down here, it gets about 120 degrees in there, i dont think this has anything to do with it though, but it just started, and i just moved into this place...(i had this crazy idea maybe the gas evaporates in the fuel lines???)
PLEASE HELP !!!!
thanks Eric
I love signatures that aren't over 400x200!
S14Speed997 is offline   Reply With Quote
Old 07-08-2004, 10:58 AM   #2
NotDave
NotDave is an unknown quantity at this point
check your spark plug wires and make sure they are connected well. also check the spark plugs if you can
NotDave is offline   Reply With Quote
Old 07-08-2004, 11:02 AM   #3
S14Speed997
I replaced my old plugs/wires with NGK's about 4 months ago, and they seem fine...
Old 07-08-2004, 11:04 AM   #4
OptionZero
OptionZero's Avatar
any smoke from the exhaust?
OptionZero is offline   Reply With Quote
Old 07-08-2004, 11:13 AM   #5
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
check the ecu for codes..
sykikchimp is offline   Reply With Quote
Old 07-08-2004, 12:07 PM   #6
S14Speed997
no, no smoke.......after it idles normal again, it runs great (except for that my car is slow lol)
I dont have a code reader thing.....im broke til the 15th, so i am planning on taking it into Nissan, have them take a look....just dont want to drive it if its serious
Old 07-08-2004, 12:38 PM   #7
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
Why not just check for codes yourself?
papershot is offline   Reply With Quote
Old 07-08-2004, 12:57 PM   #8
S14Speed997
i dont have a code reader....
Old 07-08-2004, 02:15 PM   #9
240-porkchop-sx
240-porkchop-sx is an unknown quantity at this point
you don't 'need' a reader to check the codes, you can use the light on the ecu or the check engine light....but this is all found within the search tool!
one thing to check is your gound, even make a secondary ground to the wheel bay if need be.... DJ sunrise swears by grounds..lol
also check the wires that run along the injectors....then the idle is wonky move the harness around and see if it gets worse or better.
check the MAF sensor, clean the AIV....all these things have been exhaustedly talked about...i know cuz i was yelled at by others about it...lol
also check the resistance of the injectors..should be 11ish
Black 91 s13 w/hicas, injen intake, looking for headers
240-porkchop-sx is offline   Reply With Quote
Old 07-08-2004, 02:35 PM   #10
aznpoopy
aznpoopy's Avatar
open up your hood and let someone else start the car while you look. what kind of shaking is it? does the engine flop left and right like a dying fish when you start the car? or is it a general shaking all over? if its flopping then you have bad engine mounts (maybe one broke suddenly? - weird). otherwise go check ECU codes.
aznpoopy is offline   Reply With Quote
Old 07-08-2004, 02:58 PM   #11
S14Speed997
I KNOW about the fukin SEARCH button...lol
i've cleaned MAF, AIV....checked plugs/wires...
i know my mounts are probably bad, but I dont see how 1 day its shaky (Monday) fine on Tuesday/Wed and then shittty again on Thursday...
thanks man.....im gonna read up on the codes...
Old 07-08-2004, 03:01 PM   #12
S14Speed997
Yea, i plan on doing that........both times it happened, my roommate already left, and i was leaving for work in the morning...so no time to look...
i'm not sure it its left to right, the WHOLE car is shaking....like f-in gremlins are under the hood tearing apart a deer/small mammal...i watched the tach, and it didnt move, bounce or anything...
Old 07-09-2004, 07:37 AM   #13
aznpoopy
aznpoopy's Avatar
that does seem weird. for what its worth when my car still had the original mounts it didn't always shake. it depended mostly on how cold of a start it was. if i had driven the car previous it would start up smoothly. if i was starting it up the first time for the day it would shake like a bitch (scary lol...)
Old 07-09-2004, 10:15 AM   #14
S14Speed997
well thanks for input.....this beast is paid off in 6 months, then it's getting a overhaul on maintenance....
