Old 08-28-2014, 03:46 PM   #1
zfortune
zfortune is an unknown quantity at this point
s13 Headlight problem
S13 with popup headlights always stay up when I press the button inside the car and pressed it again but still stay up. With battery connected and the button pressed in I manually turned the motor clockwise until a certain point and they will go down by themselves and they come right back up. Now I tried to disconnect the battery and have the button outwards. I turned the motor clockwise again so they go down, reconnected battery, push the button for them to go up and they do but they wont go back down when I push it again. If I press the button really fast they will stop going up.. Anyone want to put in their opinions?
zfortune is offline   Reply With Quote
Old 08-29-2014, 09:47 AM   #2
bova17
bova17's Avatar
bova17 is an unknown quantity at this point
Pull the button out and see if there is a brown wire that is cut. I'm pretty sure if it is then the only way to get your headlights back down is to turn on then off your headlights.
bova17 is offline   Reply With Quote
