![]() Join Date: Sep 2010
![]() For sale, possible trade, partial trade plus cash, testing waters. Not needing to sell but money is nice.
$8500 obo **few things I forgot, CAR IS LOCATED IN OXNARD CA 93030 CAN DELIVER CAR WITHIN REASONABLE DISTANCE REGISTERED IN FLORIDA TAGS ARE EXPIRED. Clean Florida title on hand. DOES NOT PASS SMOG IN CALIFORNIA. CAR CAN BE PAINTED COLOR OF YOUR CHOICE FOR VERY REASONABLE AMOUNT AND A DEPOSIT. 1995 base model zenki. No rust, no major damage, never hit in front like every other 240 I've seen. Link to previous owners thread... http://zilvia.net/f/showthread.php?t=384170 My goals were to make the car look as stock as possible on the outside except for wheels n tires. I've removed all the s14.5 parts and gone back to all oem zenki. Car has full functioning lights again, wipers n windshield washer work, ac works perfect. Fans come on with ac and at 190 via haltec. Had over fenders and flared-rolled fenders. All holes welded up, not just bondod up. Wheel openings have been hammered n dollied and pulled back into shape. No bondo on them but they could use Lil more work. Or overs if you like. Core support re worked to fit r32 gtr intercooler for stealthiness. Condensor and radiator moved back about 3" all custom piping made up. Motor and trans: *Garrett GT3076R dual ball bearing turbo* Full custom 3" mandrel bent from turbo back. Buddy club resonator before axle and dual 2.5" exit magnaflow at back. Looks very stock. Mazworx Ka tubular turbo manifold Turbonetics Evo Wastegate 5 pound springs (controlled by profec B Boost controller ) HKS SSQ 3rd Gen BOV SS oil feed and return lines Innovate LC1 Wideband INNOVATE*Oil Pressure, water temp, boost/vacuum gauges GReddy ProFec B Digital Boost Controller* GReddy Turbo Timer* FUEL:*Walboro 255 fuel pump Precision 780cc Injectors Turbo240 AMS Top feed Fuel Rail Z32 Fuel Filter SS Fuel line with AN fittings Tomei FPR and Gauge R33 GTR intercooler, radiator and condensor moved back to allow intercooler. Has stock bumper support and se fog lights. Full custom intercooler piping. MAf Delete (Haltech)* Cooling: CX Racing ka Aluminum*Radiator CX Racing Dual Electric fans CX Racing Aluminum Fan Shroud* 190 Degree auto on fan switch regulated through the Haltech Eagle H Beam Rods JE Forged Pistons 89.5mm dish 9.0:1 compression Hot Tanked Bore matched for Pistons All brand new Bearings, Clevite* XCessive ka-t oil pan GReddy SR20 oil sump Head:*BC Stage 2 264 Cams BC Complete head Kit, Valves, Springs, Titanium Retainers, Cometic Headgasket ARP Head Studs Intake Manifold Simplified and clear of all nonsense (EGR, IVAC) Fresh resurface with front timing cover for no leaks Tranny:*ACT 4 puck unsprung clutch ACT High*Pressure*Plate Fidanza Lightweight*Flywheel New Pilot Bearing Driveshaft*Shop 1 piece*Aluminum Driveshaft* B&M Short Shifter* B&M*Shift*Knob* Tuning/ Ignition:*Haltech E6X Standalone Engine Management System*Ls1 Coil packs (4) (Distributor Delete) Magnecor Custom Race Ignition Wires* NGK*Spark*Plugs* Suspension: Silk Road RMA8 Adjustable Coilovers* Peak Performance RUCAs, Rear Toe links Peak Performance 5 lug Hubs Z32 front Calipers and Rotors, (circuit sports drilled and slotted rotors Cusco Front Strut Tower Kaaz 2-way Stance solid raised subframe bushings. New inner and outer tie rods and boots Energy suspension rack bushings Megan raising tie rod spacer Yamato garage tension rods Wheels:*18x9.5 +23 battles with brand new 275/35 hankook ventus evo v12 tires. Interior: R32 gtr seats. Cracked dash Nice carpet, could use cleaning Has nice ac trim piece New shift boot and bezel Panasonic deck. JL audio rear speakers Infiniti reference coaxials in front Have greddy turbo timer, profec ll boost controller, not installed Innovate wide band, boost-vacuum, oil psi and water temp. Not installed. 8500. Might be priced lil high, might not. Mainly looking for cash, trades will be considered. Lmk what you have. Willing to sell with se stocks for less, Megan track coilovers for less , no seats for less. That's about it. 805-407-5415, call or text. Text is best. DO NOT TEXT ME AFTER 10PM. Any time from 6am to 10pm is fine. Last edited by SR20DET-B2200; 11-21-2014 at 09:04 AM.. Reason: reasons |
#13 |
Yes i t needs paint. I figured I'd put it up for sale as is. I know that I am a little hesitant to buy something that has 'fresh paint'
With this one there's no surprises hiding under there. |
#15 | |
GM2 (SW/AW)
So where is the car at? Your location says California and the car has a Florida tag on it..
KA-T for life! Current for sale advertisement ![]() |
#23 |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
Your parts list is right, but the appearance of your car is not.
Look at those pics, and ask yourself if this LOOKS like an $8500 car.
![]() Best way to do business with me? Make your best offer FIRST. |
#24 | |
Paint can hide a lot of bad, I'd rather have something original or showing dents than 'ready for paint' or, 'freshly painted. But that's just me I guess. |
#27 |
Pretty open to most non fwd trades. I have 10 cars and they're all pretty much projects in different stages. Would be nice to get a daily. Newer Tacoma, is300, BMW wagon, or something like that, classics are good too
battles, jdm, s14 ka-t, these battles are real, turbo, you buy now |
