Old 08-31-2014, 10:50 AM   #1
Bleakley
Bleakley is an unknown quantity at this point
2005 G35 twin turbo parts list
Put this together quick for a friend. Thought I would share it. OBVIOUSLY none of it is set in stone. It is literally a first draft that took 15 minutes to write up. I know it has been done already and I do not care. Feel free to comment and discuss.
Would be badass if he finally actually decided to say eff it and pull the trigger on this..
Infiniti G35 VQ35DE Twin Turbo build:
Turbo Manifolds - $600?
gaskets (manifolds, flanges, and outlets) - $70
Turbos, 2x GT2560R (V-Band for exhaust simplification) - $2,000
PTP Turbo Blankets - $350
Tapped oil pan - $20 + weld
Oil pan gasket - $20
RTV - $20
Tapped coolant and oil - $50
SS oil and coolant turbo lines - $200
CX Racing dual 2.5" in x one 3" out IC - $200
Air filters - $100
Induction piping - $100
A lot of couplers - $50
2.5" IC piping, turbo to IC - $100
3" IC piping, IC to IM - $75
BOV and recirc tubing (y to inducers) - $300
vacuum tubing - $25
MBC - $25
2.5" Turbo elbows to stock downpipes:
 2.5" V-band elbows - $200
 2.5" Downpipes - $150
Dual 2.5" Cats between DP and X - $600
2.5" - 3.0" X - $40
Gaskets - $50
Oil Cooler w/fan (remote and dual filters?):
 Upgrade to dual filters and fan = $300
Maybe even trans. cooler with fan - $100
bolts and washers - $50
Bosch 044 Fuel Pump - $250
Injectors - $600
Adjustable fuel pressure regulator w/ gauge - $200
spark plugs - $50 for 2 sets
Ignition setup (stock? Convert?)
Oil, filter(s) - $25
Gauges:
 Oil pressure - $70
 Fuel pressure - $200
 Water temp. - $50
 Wideband AFR - $200
 Boost/Vac - $60
Wiring and connectors for gauges - $100
JWT or AEM ECU and TUNES!
Target HP would be 525whp and 450+ ft pounds
Cost - ~8-10ish, probably more...
Bleakley is offline   Reply With Quote
g35, twin turbo, vq35de, vq35dett
