Old 09-22-2014, 06:45 PM   #1
nik1206
nik1206's Avatar
nik1206 is an unknown quantity at this point
Stupid sr20det timing question
i am in the process of taking apart my first sr20, and i am about to reinstall the timing chain except i ran into a small problem. i wanna make sure i get it right.
the crank sprocket has two marks on it and I'm not sure witch one is the correct mark. I've been searching all day and i haven't been able to find anything talking about two marks.
if anyone could help it would be awesome.
File Type: jpg 10649622_966501276699309_947352723131173444_n.jpg (59.4 KB, 15 views)
nik1206 is offline   Reply With Quote
Old 09-22-2014, 06:46 PM   #2
nik1206
nik1206's Avatar
i posted a picture of the sprocket just incase no one knows what I'm talking about
Old 09-22-2014, 09:35 PM   #3
Kingtal0n
Kingtal0n's Avatar
I never try to line anything up that way.
Get the engine tdc piston #1, then set the camshaft positions, 10 and 12 like all the diagrams and google searches should show. Something they do not show often but is very helpful is the lobes of both camshafts (for cylinder #1) will be pointing almost perfectly outwards, that is, along the horizontal plane of the deck. I say almost perfectly, because they are angled very very almost imperceptibly up.
And thats it. Ill repeat it a different way.
make sure piston #1 is TDC, then set the lobes of both camshafts facing outwards. Double check the dots on the camshaft sprockets are 10 and 12 o'clock and count the links between them.
Old 09-23-2014, 03:11 PM   #4
nik1206
nik1206's Avatar
awesome thanks for clearing that up for me man!
Old 09-23-2014, 03:17 PM   #5
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
http://www.nicoclub.com/archives/how...0det-head.html
Should b everything u need from top end, timing info from the head is allthe way at the bottom
Primo's Silvia is offline   Reply With Quote
