Old 10-05-2014, 01:25 PM   #1
wawazat8402
wawazat8402 is an unknown quantity at this point
Send a message via AIM to wawazat8402
FS: GTX2867R SR20 Setup
Well, I am moving on to a larger setup so this one is up for sale. It is a great midrange power setup and provides power deliver that reminds me of my old G8 GT. It would provide a solid setup for great response and 375-400whp depending on the rest of the engine.
I put maybe 500 miles on this setup. The rings on 1&2 let go but no catastrophic failure or debris found anywhere in the engine. They just wouldn't make enough compression for the engine to start again
It will bolt up to a stock O2 housing down pipe setup. Custom hot pipe and intake may be needed.
Price: $1,800obo this is well over $500 less than it would cost to piece together new. Willing to ship at buyers expense.
The setup consists of the following:
GTX2867R with .64 AR IWG turbine housing
Codyace modified stock SR manifold for Tial MVS EWG with Swaintech White Lightning coating
Braided coolant and oil lines for S14 water neck with oil restrictor
Tial MV-S wastegate with open dump pipe currently using red and black springs for 1 bar base pressure
Extra springs for other base pressures (white, blue, yellow, green, gold)
You can see the bracket I used to hold the IWG flapper shut without welding it. IWG could still be used if wanted.
Mild steel dump pipe with heat wrap.
Spare springs
Synapse DV
This thing is more compact than their BOV, however, it must be recirc'd. It had super fast response and for those that care was still audible when recirculated properly.
The DV is a little scratched up due to being tucked under my hot pipe to keep it out of sight. I have a brand new aluminum weld fitting for it that is included. The silicone couple going to the intake pipe is also included.
Price: $150
I can meet anywhere in OKC and depending on amount of parts bought, maybe further like Tulsa.
Item will ship within 1 week of payment being received. I work a crazy schedule but will provide updates and get it on its way within this time period.
wawazat8402 is offline   Reply With Quote
