Uniform Tire Size on Staggerd Wheels
I've got 17*7 and 17*8 Volk wheels and am currently buying tires. I notice most with staggered wheels also stagger the tire size using wider rears.
I'm planning on using 225/45/17 all around, which means the front should stick to the pavement a little better and the rear should be more responsive (less bulge on sidewall), qualities which should balance the car (produce less understeer), right? Any issues I haven't thought of? Anything wrong with my plans. FYI - It's '91 a daily driver s13 and tires will be, Bridgestone S03's or Pilot Sports (am still kicking around the idea of Azenzis Sports but they'll have less wet traction). I'm still KA so any of these should offer more than enough grip, and I can change the rears for drift if desired. Thanks for input/opinions!
'93 Fastback LE - Wrecked '91 Fastback HICAS and LSD - Sold '93 Fastback SE - Current |
![]() Join Date: Mar 2002
225 fits perfectly on my 16x8. not stretched or anything.
but 225 on 7s... hmm.. the tire will prolly bulged out a little bit.
![]() ==>>TGL GARAGE<<==.. RIP! S13 coupe KA-T @ 0.5 Bar = SOLD! A31 Cefiro + SR = Current |
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
ive got the same setup your thinking. 17x7, 17x8. 225/45/17 all around. i bought my wheels and tires at the same time but 5zigen sent a staggered setup instead. the tires are toyo proxes 4. theres no bulge in the front whatsoever, perfectly flush, the rear have very slight stretch to them so they could use a 235 and that would be perfect, ive got pics if you need them
#6 |
I have the same size wheels. I started out with 215/45 front and 235/40 rear, but that created some understeer and they bulged a little bit all around. Next I went with 215/45 front and back which gave me a tiny stretch in back and really helped with balance. Now I'm running 205/45 all around. The front tires are perfectly square, and there is a pretty decent stretch in back so it feels great on breakaway. The shorter sidewall helps response and gearing as well.
#7 |
i was thinking about doing that setup(205 all around) but i thought it might look wierd with stretched rear and flush front. and i didnt know how much stretch it would give and how much and if any traction i would lose
#8 |
from Canada, eh!
![]() Join Date: Sep 2001
I have 17x7 and 17x8 and i run 225/45 in front and 245/40 and rear and the tires don't really buldge...
As for my track wheels, I am running 225/50 and 245/45 on 16x7 and 16x8 rims... but A032R buldge a little more. ![]()
-> HaLo Race Car: '98 E36 BMW M3 Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
#9 |
![]() Join Date: Nov 2001
you have 17's, this means you have the luxury of going with a very wide rear tire (255 or so). Personally, I would stagger stance.. who cares if you have more tendancy to understeer.. its worth it if you're running quality tires (s03s are top flight). I'de run 225 or so in front, and 255 or so in rear.
There's no sense in running 225 in the back, for what reason? You're not gonna rotate. When maximum traction is your goal, over or under steer isnt really such a big deal.. its just a handling characteristic. Besides, all that can be changed with your suspension setup (adjustable shocks, coilovers, etc) - Mike |
#10 |
I'm going to have to respectfully disagree. Balance is ALWAYS important. Much more important than maximum grip. Having a car that pushes wide sucks. Period. He didn't say what motor, but if he's on a stockish KA then 255s in back is just silly. It's going to take a lot more than a few clicks on the shocks to rebalance the car.
#11 |
![]() Join Date: Feb 2003
I run staggered 5zigens with uniform tires as my back up wheels, 17x7.5 and 17x8. I use 205/40/17 on all 4. Im pretty happy with them, but i dont use them for grip driving.
#12 | |
That was the biggest bunch of misguided fucked up information ive read today.
90 S13:............fitter, happier, more productive. 04 Yamaha R1: 210rwhp on gas/161rwhp on motor |
#13 |
if you arent concerned with "drifting, yo" why does it matter how a car is going to perform when being pushed at the absolute limit? basically, you guys want a car that will completely oversteer when you're in the canyon -- or, do you want something that actually has traction. i dont know how you guys drive, but i still managed to break 225's with my SOHC KA. That was the biggest bunch of misguided fucked up information ive read today. suck the dillznack. |
#14 | |
![]() Join Date: May 2002
At least with the stock suspension, 205s have enough grip for ANYTHING you can do on the street (that isn't stupid) with a KA. If you're talking about wide wheels and 255 tires.. well, you're right, you'll probably never break them loose. But on any sort of track - autocross, road course, pick your poison - you're just going to slide the 225s you have up front and understeer, unless the suspension is worked to compensate. You'll end up slower than running 225s all around because you'll still be limited by the grip of the front tires and the car will be harder to control. Of course, there's no reason the suspension can't be worked to compensate. Stagger isn't a bad thing in itself... if you have a whole lot of power it'll make everything that much more controllable. Like everything else... it depends on your goals. Just like picking a turbocharger (response versus power), you choose balance or maximum grip. If the car is never going to leave the street, stagger it, it won't hurt. |
#15 |
when you're foot is mashing the gas often times you can forget about what the front tires are. if you play with various types of quality tires, you'll notice that size doesnt always matter -- compound does. i've ran 245's that grip less than 225's. sidewall stiffness also matters. so, might as well try before you straight up say on a forum "this WILL work" or "this WONT work" etc etc.
i run 245/45/16 front and rear and the car is very neutral. go too fast into a turn and you CAN understeer depending on the balance of the car (and type of turn). go fast and mash the gas and of course, oversteer. i just think its funny when people talk as if they are the drift king and as if they are going to drive "drift" on the streets. i mean, anyone who drives balls out on the canyon will understand that balance and grip are most importnat, and that specs dont always equate. so, the driver has to be in-tune with the car and know how to control their vehicle. ive raced plenty of cars that LOOK cool but hey, how cool do they look when they're in my rear view mirror. drifting isnt so cool when the person just got their ass handed to them. - mike |
#16 |
Wait, I'm confused. First balance isn't important, but now it is? Why are you bragging about how neutral your car is with non-staggered tires and proving my point for me? Who said anything about drifting? Trying to make your car rotate nicely doesn't make you a drifter. I've been autocrossing for years. You need to pick an argument and stick to it.
#17 | |
..........wow ![]()
#18 |
ehh, your use of the car and driving style should tell you what you need, there are always sacrifices with each choice, wide tires are awesome if grip is what you want, but too much and you will wear only the insides exept during hard cornering, i ran 245/40/17 on a 17x8 with around 32-35 psi on a 44 max rated tire and the insides were bald while the outsides looked almost brand new. so there is a point of going too wide that you dont get the best contact patch.
#19 |
That just means you had too much negative camber or toe-out. both of which indicate to me your car would've understeered more if your rear alignment was set properly.
#20 |
wouldnt only the insides be worn if that was the case? car was on h&r springs with agx's and otherwise stock suspension and was aligned by a very reputable shop.
#21 |
orange ghey> Wait, I'm confused. First balance isn't important, but now it is? Why are you bragging about how neutral your car is with non-staggered tires and proving my point for me? Who said anything about drifting? Trying to make your car rotate nicely doesn't make you a drifter. I've been autocrossing for years. You need to pick an argument and stick to it.
since you want to be such a smart ass, why dont you quote me.. WHERE did I say "balance is not important." Hmm.. search says: "! Finished Searching the Document" -- thats right, 0 finds.. because I didnt say that. YOU are the one arguing, I am the one just speaking from MY perspective. Thats all this is, its a forum fucknut, people talk and share THEIR experiences. No one is 100% correct in this situation because its about give and take, every driver has their own preferences that apply to how and where they drive. Besides, if its one thing I dont do is brag about my car.. I'm not a fake fuck who hides behind his material possessions. Hence the reason why I can drive a stripped down POS13 and not give a flying fuck. The point I was making is that understeer and oversteer arent "end of the world" characteristics like SO many people think it is. People watch "drift bible" and they take it to heart, like all of a sudden OVERSTEER is the shit and thats how TRUE performance cars should be setup. True performance cars should be setup to be driven, especially street cars. HOW it is setup, all applies to what the driver wants. Realize. ehh, your use of the car and driving style should tell you what you need, there are always sacrifices with each choice, wide tires are awesome if grip is what you want, but too much and you will wear only the insides exept during hard cornering, i ran 245/40/17 on a 17x8 with around 32-35 psi on a 44 max rated tire and the insides were bald while the outsides looked almost brand new. so there is a point of going too wide that you dont get the best contact patch. no, akadriver is right, your alignment is OFF buddy. this is why I dont run much negative camber on my street car, no more than 1.25 or 1.5 degrees.. somewhere in that range. I've chewed threw tires before, smart enthusiasts dont want to wear the insides of expensive super sticky tires. |
#22 | |
#24 | |
hehe |
#25 | |
#26 | |
fortunately for me, my personal experience involves racing against cars that cost six digits and seeing them in my rearview mirror. is that bragging? nope, its called reality. ps: this has nothing to do with ego, i just hate hearing people speak as if THEIR way is the ONLY way. like i said, so many different ways to setup your car.. and it all depends on how you drive and where you drive. stop speaking like you're suggestions are the ONLY methods to attaining a nice handling car, drift king. |
#27 |
You still don't get it. I am not talking about drifting. I am not talking about massive oversteer. I'm talking about making a car neutral, which is a very important goal in any type of motorsport involving corners. It's also independant of ultimate grip level, so putting skinnier tires on your car isn't going to affect balance, only grip. Two seperate things. Staggered tires DO affect balance negatively and don't increase ultimate grip unless you have the power to take advantage of it. This isn't something I made up, it's simple vehicle dynamics. Increasing understeer doesn't "work" for anybody, and unless you drive like an 85 year old woman it is something to be avoided at all costs.
#28 |
awesome -- keep repeating yourself and maybe you'll eventually convince yourself that going with a 205 tire versus as a 235 was a GOOD choice and gives you MORE traction. Increasing understeer doesn't "work" for anybody, and unless you drive like an 85 year old woman it is something to be avoided at all costs. you spend too much time trying to disagree with ME, rather than look at the original post by the author of this thread. owner has purchased 17x7 front - 17x8 rear volk wheels he wants tires, he wants traction, he wants to chose a size, simple! pick a tire that will square up with the rim. for the front's, I would go with a 215 or 225. for the rear, i would go with a 245 or 255. why go with a 215 or 225 on an 8" rear wide tire? all you are doing is limiting yourself on rear traction. more rear traction means you can get on the gas earlier and keep the back planted, put all that weight and stress off of the front tires and on the BACK and power out of the turn. what you are talking about is how the car will handle neutrally (without shifting the balance of the car) but regardless, anyone driving aggressively will want that rear traction because thats what you do with a RWD car.. you plant the back and power out of the turn. |
#30 |
You're exactly right, the 205 provides less traction. And the car is faster autocrossing than it ever was. Why? Becasue I could never effectively use the grip the 235s provided with only a stock KA. Whenever I hit the gas in the middle of a corner the the backs would grab and the fronts would just push wide. I would have to lift off to get the car back on line. Now I hit the gas and the car just turns in harder. Nice and neutral. The car is also much smoother on breakaway with the stretch, compared to the sloppy snap oversteer of the 235s when they finally gave way. As far as square, all of the sizes you listed will bulge, some terribly, making the car feel mushy and unresponsive at the limit. Are we done yet?
