Old 10-19-2014, 11:10 AM   #1
flatlands532
flatlands532 is an unknown quantity at this point
CA FS CA18DET engine, trans, nismo mounts, clutch etc.
Im selling my ca18det and all parts for it.
Nismo motor mounts, installed, never used - 225$
CA18DET transmission - 150$
Stage 3 Clutch kit - 125$
Resurfaced Flywheel, never used after machining - 75$
3 piece Radiator hoses, green - 40$
New Nissan Thermostat - 20$
Any intrest in the full motor or parts of the motor just let me know what you need, will sell motor as is, missing a few things. Motor has brand new oil pump but has not been put back together after that. (timing belt, tensioners, water pump etc.) also has a brand new nismo crank gear.
Located in Chicago, will ship at buyers expense
flatlands532 is offline   Reply With Quote
Old 11-14-2014, 02:36 PM   #2
Ca-burner
Ca-burner is an unknown quantity at this point
I can use the engine harness, 2196138381
Ca-burner is offline   Reply With Quote
Old 11-14-2014, 02:49 PM   #3
ZakS13
ZakS13 is an unknown quantity at this point
Looking for:
Lower Intake Manifold w/ Butterfly valves and actuator
Exhaust manifold
Exhaust manifold heat shields (if they are available)
shipping to 48708
also, out of curiosity, what do you want for the assembled engine alone?
ZakS13 is offline   Reply With Quote
Old 11-15-2014, 01:05 PM   #4
omgwtf
omgwtf's Avatar
omgwtf is an unknown quantity at this point
stock cams?
omgwtf is offline   Reply With Quote
Old 11-18-2014, 03:55 PM   #5
ca18_driver
ca18_driver is an unknown quantity at this point
I need the dropping resistor
Please call or txt 9095282710
ca18_driver is offline   Reply With Quote
Old 12-09-2014, 07:12 PM   #6
dhen
dhen is an unknown quantity at this point
Is the engine still for sale? How much do you want for it? Is there anything wrong with it?
dhen is offline   Reply With Quote
Old 12-28-2014, 08:33 PM   #7
Rubean22
Rubean22's Avatar
Rubean22 is an unknown quantity at this point
What brand are the radiator hoses? Also, is the top hose one piece and the bottom hose 2 pieces?
Rubean22 is offline   Reply With Quote
