Old 11-17-2014, 03:39 PM   #1
inlineesiixxx
inlineesiixxx's Avatar
inlineesiixxx is an unknown quantity at this point
s13 New Brakes!
I want ceramic pads but my local stores (where i get discounts) don't carry ceramic pads for non ABS 240s. I looked up the differences between the ABS and non-ABS parts and found that the ABS rotors are a couple mm different in dimensions. The calipers, however, have the same part number. my question is -- are the ABS pads the same as the non abs pads, but a different material? If not, can I buy the ABS rotors and pads even though i don't have ABS? Im thinking the only thing different would be a couple mm on the rotor and a spot where the ABS would hook up. thanks in advance!
and unless you have an amazing deal, I don't really care to do a brake conversion
inlineesiixxx is offline   Reply With Quote
Old 11-18-2014, 12:13 AM   #2
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
One time i really needed to move my car and i used a rear abs s14 caliper with my non-abs pads and rotors on my hatch , it worked with no prob i just couldnt use the ebrake but i was only moving it to buy another s13 caliper.. Ohh and also i used the s14 abs rear rotors with my s13 rear brakes to redrill my new rotors from 4lug to 5lug with no problems hope this give some info
Originally Posted by adams 02rs View Post
Here yee have found zilvia...WELCOME TO HELL.
Primo's Silvia is offline   Reply With Quote
240x, brake, brakes, ceramic, s13
