Old 11-24-2014, 02:08 PM   #1
lunzee
lunzee is an unknown quantity at this point
Sr20det ran out of gas, won't start
So did a track day. Car ran completely out of gas whilst drifting. Pushed car to the pits, put in two gallons, won't run. Starts if cranked continuously but just dies without throttle, won't rev, just Boggs, I'm going to pull fuel pump when I get home but would like to hear opinions. I primed it multiple times, kept it running for 15 minutes or so like this to see if it was just air in the lines and nothing helped.
I would drive it like I stole it, but even then I would be more careful
lunzee is offline   Reply With Quote
Old 11-24-2014, 07:31 PM   #2
s&tcustoms
s&tcustoms's Avatar
s&tcustoms is an unknown quantity at this point
My money would be on the fuel pump.
s&tcustoms is offline   Reply With Quote
Old 11-24-2014, 07:45 PM   #3
Sills
Sills's Avatar
Sills is an unknown quantity at this point
Fuel pumps use the fuel as lubrication and can overheat and die quickly after being ran dry. If you have fuel in the tank now you should easily be able to hook up a 12v source to it and hear if it runs or not.
Sills is offline   Reply With Quote
Old 11-24-2014, 08:14 PM   #4
JSimpson
Banned from the Marketplace
JSimpson is an unknown quantity at this point
the walbro style pumps die as soon as they run dry. The bosch motorsports pumps can be run dry but obviously its not good for them
JSimpson is offline   Reply With Quote
Old 11-24-2014, 08:14 PM   #5
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
Most likely fuel pump, best way for sure is to check fuel pressure coming from the pump
Originally Posted by adams 02rs View Post
Here yee have found zilvia...WELCOME TO HELL.
Primo's Silvia is offline   Reply With Quote
Old 11-24-2014, 10:34 PM   #6
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Hook up a fuel pressure gauge and make sure it's within spec with and without vacuum to the regulator.dont start the whole parts still it starts stuff when you can do some simple diag first.
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 11-24-2014, 11:33 PM   #7
tiqichale
tiqichale is an unknown quantity at this point
tiqichale is offline   Reply With Quote
