92 sr20det black top 24k miles tons of mods
SO I am trying to sell the motor complete with clutch and trans. Would like to get it all out at the same time. I will part up the trans and motor, at the moment I do not want to part the motor till the car comes off the road for the winter.
It is a 92 SR Blacktop that has been rebuilt from the ground up. the only parts of the bottom end that are from the original motor are the block, crank, caps, craddle, and upper oil pan. The head has been fully port and polished, solid lifters, new valve guides, decked, squelch pads cut, and valve job. This would come as a complete swap, unless there is a large interest in parting out. Here is a complete list. Engine; Top end; chemically cleaned Full port and polish gasket matched intake and exhaust Head Bolts, ARP rocker arm stoppers, Greddy solid lifters, tomei cams 270 in 270 out 12.5 high lift, tomei adjustable cam gears, tomei type A single springs 12.5 high lift, tomei 3 angle valve job, and ressed valves Valves were unshrouded for better breathing and combustion decked flush new timing chain tensioner, oem polished intake plenuim gasket matched, greddy knock off 321 steel mandral bend exhaust manifold. cold spark plugs, NGK 8 1.2mm metal headgasket, Cometic Bottom end; Chemically cleaned block Decked Crank- micro polished, 2 pounds shaved, balanced Pistons - CP, Balanced to crank Rods - Eagle, Balanced to crank Mains - ARP Rod Cap bolts - ARP New oil pump timing cover - OEM New water pump - OEM New guides - OEM New timing chain - OEM New tentioner - OEM New oil strainer -OEM Motor mounts - Nismo Alternator - Quest 110 AMP Oil filter sandwich plate - Circuit sport Oil lines -10 AN - Custom Oil filter relocated to frame rail Oil cooler - 14 row ebay Over sized, baffled oil pan - Tomei Turbo setup; HX35 7 blade turbo from 2003 dodge cummins diesel CRX forward mounted top mount manifold -6 AN oil inlet feed -12 AN oil outlet Flap welded shut for external wastegate Tial external watsegate 18PSI spring weight ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() If anyone would like specific pictures, let me know |
#6 |
#8 |
https://www.youtube.com/watch?v=htZVVQ3WGYs
In case anyone was wondering sound or if it is running. Yes it is currently running and in my car. Please let me know if the link is broken. |
