Old 07-24-2004, 01:38 PM   #1
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
nailed myself with a bolt
so i've been installing my energy suspension bushing kit. all of em are in and perfect cept for the front and rear control arm bushings. Front Strut Rod Bushings, front sway bar bushings, rack and pinion bushings, rear sway bar bushings, and rear sub frame inserts... now the control arms are kicking my BUTT.
it is a very rare thing for me to leave something to a professional. either its something i can't get perfectly perfect, i simply can't figure it out, or i'm pretty sure i'd kill myself trying to accomplish it. so i tried to tackle the front control arms and round one ended in a bitter defeat. i felt like goliath vs david. a freaking pussy. so my next idea was to press the bushing out with a large bolt and a bushing press.
right about now is where the sinister horror movie music cues up.
everything looked good then the bolt started doing a leaning tower of piza impression and BA'AM it turned into a tomahawk missle headed for my rib.
nailed... by a bolt.
my rib is bruised like a mofo. it broke the freakin skin... eek. i guess i got off light but monday a tech is sposed to handle the situation.
i'll put a review up for the bushings when the car gets ready to roll. the kit is AWESOME. very good instructions, the best i've ever seen. actual photos. the rear subframe inserts, front strut rods (aide from needing them pressed in) and sway bar bushings are the easiest. CAKE. the only ones that gave me trouble were the rack and pinion and the obvious control arms (to be completed).
took me 4 hours for everything i've completed thus far with air tools and a lift.
MakotoS13 is offline
Old 07-24-2004, 02:17 PM   #2
element240
element240's Avatar
element240 is an unknown quantity at this point
Send a message via AIM to element240
it's your own fault for not wearing a bullet-proof vest
element240 is offline
Old 07-24-2004, 02:20 PM   #3
Andrew Bohan
Andrew Bohan is offline
Old 07-24-2004, 05:24 PM   #4
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
i hope your ok Doug. you so silly.
hydropgrahics!
ls1......
420sx is offline
Old 07-24-2004, 07:30 PM   #5
max240
max240's Avatar
max240 is an unknown quantity at this point
The lower control arm bushings arent too bad to install.. You have to melt the old bushings out. use a propane torch and heat the outer metal sleeve of the bushing. you will see the bushing melt out off the outer edges. you can then press them out with a screwdriver. you can then push the es bushings into the outer sleeve by hand.. dont use the t/c bushings though, they will crack your lower control arms from too much twist load.. i have broken 2 arms before i just bought a pair of ball end rods..
max240 is offline
Old 07-24-2004, 10:25 PM   #6
AKADriver
AKADriver's Avatar
word.. take those "strut rod" (tension rod) bushings OUT before they ruin your LCAs!
AKADriver is offline
Old 07-24-2004, 10:46 PM   #7
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
dammit, I just installed TC bushings..
thelinja is offline
Old 07-25-2004, 04:01 PM   #8
kanekz
kanekz's Avatar
kanekz is an unknown quantity at this point
Onetime...I stapled my finger with a stapler. It was weird feeling. I wanted to take the staple out..but thats actually the hardest part. While its in there..it doesnt hurt..but after you take it out..then it hurts. weeeeeee!
Blitz!!
kanekz is offline
Old 08-08-2005, 11:47 AM   #9
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
Why does the ES teinsion rod bushing do that?
CHARLIE2020 is offline
Old 08-08-2005, 12:01 PM   #10
S14DB
AFC #1
S14DB's Avatar
Why did you feel the need to bump this?
S14DB is offline
Old 08-08-2005, 12:07 PM   #11
MakotoS13
MakotoS13's Avatar
dbya tea eff mate?
Old 08-08-2005, 12:08 PM   #12
Mervyn
Mervyn is a well-known jackass
hope you feel better soon.
Mervyn is offline
Old 08-08-2005, 12:24 PM   #13
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
hahha, it happened when Doug-Eat-Doug did this a year ago. im sure he's healed. But im not sure if he's mentally stable, but so long as he's physically heal, the ladies will love.
SochBAT is offline
Old 08-08-2005, 12:44 PM   #14
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
so uhh...have your control arms broken off yet?
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline
