Old 01-20-2015, 02:49 AM   #1
silvia_fiend
silvia_fiend is a jewel in the roughsilvia_fiend is a jewel in the roughsilvia_fiend is a jewel in the roughsilvia_fiend is a jewel in the roughsilvia_fiend is a jewel in the roughsilvia_fiend is a jewel in the roughsilvia_fiend is a jewel in the rough
SR S13 sr20det help
People of zilvia I need your help.
www.youtube.com/watch?v=8Ha9yMVuY_c
This is my car, jdm s13 with what I believe is a 180sx blacktop swapped in.
Mods:
440cc S15 injectors
T28bb
RB25 pink sticker afm
Full exhaust
PSM intercooler
EBC
Chipped ECU
Since I've owned the car there has been an issue with the idle and initially running very rich, the tune really helped things there but the idle would still surge/hunt and stall when clutching in rolling to a stop at lights etc, tuner wound the idle up which was a band aid fix but did the trick.
Fast forward to at least 6 drift days and a lot of driving later and the car runs great, but still has the idle issue and as you can see at the video still stalls out with a lot of momentum when clutching in and braking hard, usually when I spin it it'll stall too.
Things I have done, cleaned out IACV and put another in from a spare manifold, set TPS at .4v, cleaned MAF. The issue still persists.
The tuner mentioned the CTS reading was through the roof when we were tuning and I made a mental note to look into it, (he also disabled/tuned around the o2 sensor so that has been unplugged since the tune) recently bought a new CTS and installed which made no difference, however I did notice that the plug the CTS and temp sender for the dash connect to had the two trace wires (I think orange and blue) taped up, peeled the tape back to find them back to front i.e. orange connected to blue and vice versa, this is on the loom side of the plug.
At the same time I bought a consult cable and hooked up to my laptop, noticed with the engine not running the water temp was sitting at 50*C after switching the wires round the to the correct way the temp reading goes down to 30*C.
Now for the really strange part, the ECU was throwing no codes for the CTS even though those wires were back to front, does this make sense? After I switched them my cluster temp gauge stopped working so I switched them back and then started to get the CTS code.
I'm extremely confused, things I'm planning to check/try other parts are the AFM, vacuum/boost leak check, timing. Any other suggestions? What gets me is the car was running great, besides the idle, and now it's gone back to running really rich, wouldn't start a couple days back and I pulled the plugs to find them all black, I'm wondering if rewiring those wires has thrown the tune off after the tuner maybe compensated for it originally?
Any help or advice is MUCH appreciated!
silvia_fiend is offline   Reply With Quote
