![]() Join Date: Jan 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Forgive the dirty shot but you get an idea of the time just spend making the engine bay look uber Sexy ![]() ![]() http://www.youtube.com/watch?v=KOWOWhEYOhg ![]() The Good : -Tein Tie Rods (VERY GOOD QUALITY ) -2nd Owner -Carpet can be lifted so you can see how clean the floor is -I'm not trying to cover anything up -Primered by AUTOMOTION -Registered in California / Not Operational / needs smog in place of the SARD TCV you could install a cat and most likely pass with flying colors. -145,000 Miles on the chasis -Was Automatic, now converted to 5-SPD - 5 Bolt Conversion - R33 GTR Calipers -Project Mu Rotors slotted Tockiko Pads + ARP Extended studs (Steel Braided brake lines) -30 mm spacers in front -Full Megan Multilink Kit (New Generation) -Bings RUCA (New Generation) -JDM VLSD and 5 bolt shafts are almost with fresh redline diff fluid - Rear Brakes are all new Original calipers with new Brembo rotors n pads -Steal braded lines -9000 RPM JDM Cluster HUD (UBER RARE ) -Tein HA Rear adjustable Coilovers with Dampening adjust and work with EDFC -Cusco Front Coilovers needs rebuild/replace -Rare MINES S13 Front Strut Bar -Rear Megan Strut Bar -Walbro High Flow Fuel Pump - 0 Gauge Battery Relocation kit with Moroso Racing Battery Box - RED Top Optima Solid State Battery - S14 Lower Tables with new bushings -Kazama Engine Torque Dampener Volk Racing GT-P 17x8 17x9 and Hella Clean/Hella Flush - Silvia S13 Front end conversion comes with a set of Bricks GTR grill with Silvia Tripple Projector Headlights and Silvia K's Aero late model Bumper which is worth over a thousand dollars... Engine : Black Top S13 SR20DET This is genuinly one of the cleanest SR black tops you will find. Its running in Mint condition. This motor has always been babied. -Clutch is a Exedy Stage 1 less than 100kms on it. -Stock manifold will be included, no turbo. -Always Mobile 1 5-50 -Tranny has Zero ginds and its like day one -Red Line Shock Proof Heavy Duty synthetic Gear Oil Turbo setup : GT2860RS Disco Potato 0.86 A/R Turbo VERY Clean (less than 3K no shaft play) DC Sports Manifold (True equal length)(Reinforced ) Taka Turbo lined with oil restrictor New gasket from Nissan Silvia S15 7 Layer Matal $80 Quietest exhaust for street Apexi Super Hybrid Megaphone Option of Dart Izzimi for $500 extra - BLITZ URAZ CHASIS DYNAMO BNIB VERY RARE LIMITED EDITION WHITE -Greddy Intake Maniforld with VQ45 Throttle body port matched - Thermal Intake Gasket from Circuit Sports -C'S SHORT SHIFTER Uber rare, best feeling, most precise shifts of any car :P -CS shift fork return ball -GREX SHIFT KNOB -CUSCO BRASS SHIFTER BUSHING Custom Intercooler Piping is MID-Mount and Very nicely done by JR @ Autoworx - JDM GANADOR Mirrors Mint condition - 2 X HKS Filters You all know how much these go for one is new one is almost new - COMPLETE JDM Climate Control With all plugs and Sensors -Megan Downpipe With Flex (O2 Bung welded in) - Energy Steering Rack Bushings -DIF Solid Aluminum Steering Rack Bushing Nismo Engine Mounts Nismo Oil Cap Bings Coil Pack Cover Black -SARD TCV ( TORQUE CONTROL VALVE ) -S14 Power Steering Reservoir ( Clear bottle ) -Nismo 740cc injectors already in SR Fuel rail S13 SR Ignitor KOYO ALuminum RAD + 2 X Flexilite Fans -300ZX MAF with pigtail and HKS Filter - Greddy VSPL FMIC with piping - Greddy RS BOV - Greddy Profeb B Spec II Brand New but installed - DIF Aluminium steering column bushing Solid Steering feel -S15 Silvia Autech seats Blue Suede - 5 X Defi BF Amber gages + Link Unit with wires n Nissan sensors -2X Water Temp -Oil Temo -Oil Press -Boost -Fans and Fuel Pump directly fused to battery ( Was requested by tuner) - Professionally Wire Tucked so Engine Bay looks Uber Clean -Sparco Race Steering Wheel in Suede -Innovate Wide Band O2 sensor no installed brand new in box Paint is Paladium Silver Metallic done by Tomas at CARWORX I have had this car since 2004, title is clean and have been building it up slowly but with choice parts as this was going to be a keep forever kind of car and as I have been tempted in the past to sell it. I guess it may be time to move on... The car speaks for itself as its a hellaciously clean chasis with the best parts money can buy. Please make offers. I'm willing to add a bit of cash depending on your trade should there be a trade. Car Made 312 Wheel HP 280+ ft-lb torue Tuned by Pat ACSP on a MUSTANG DYNO with a small boost leak on a hot day on fully stock motor on 94 octane I am religious with oil changes every 1000 miles and you can see how this car was built. The Bad: Small paint chip on drivers side fender Windshield has a small crack thats not in the vision of driver, the drivers side window stopped working and now it needs a battey but the optima red top should still be under warranty, such crappy batteries... paint could use Wet Sand and Polish as clear was never polished after it was painted, small chip in fender on drivers side... -------------------------------------------------------------------------------------------------- Serious Inquiries Only Do Not Low Ball me No Tire kickers Trades I'm interested in Honda S2000/ Kouki S14 equally or slightly less modded /Nissan R33/Toyota Supra/350Z Manual Hard Top, Only or equally built and clean Nissan 180SX I am forgetting tons of mods and you can count on the fact that you are saving thousands in time labor and mistakes that cost me instead of you. $9,500 Negotiable $8,000 No Rims... Optional Single Axle Trailer $1,500 The trailers bed jacks up for ease of loading and unloading for lowered cars... Trailer plus Car $10,500 Four new straps, winch, tire rack and new wiring, bearings and races plus new tires. Ready to go to any race track in North America ADD IT UP and You see where I spent on Reliability and spared no expense. My plan was to hit 400 wheel so you have ALL the Supporting Mods, Apexi POWER FC Stand Alone with commander and the very very rare Datalogit module plus software FC Data log I built this to be a daily driver/weekend track beast The powerband is very linear and my tuner thought my car was equipped with cams yet they are stock and pull hard all the way to redline I can deliver within reason for gas obviously but not 30 hours away
FRIENDS DONT LET FRIENDS DRIVE STOCK 1992 Coupe SE Last edited by driftertim; 09-30-2015 at 08:56 PM.. |
Bump for new lower price $11,500. Interested in trades for Toyota 4Runners 84-89 built rock crawler Solid Axle Land Cruisers any year built or not built plus cash depending on year and condition. Keep the offers commin yall and thank you for the complements
FRIENDS DONT LET FRIENDS DRIVE STOCK 1992 Coupe SE |
#6 |
BUMP, no longer interested in trades unless its very legit, too many bogus offers that just make me want to keep this car forever. Thanks
#7 |
Im lowering my price to $11,000. Wondering if anyone wants an authentic well built car?
#10 |
$10,500 and that is because I looked around, there were way lesser cars for more money, seems like people are scared to pull the trigger on such cars, I wouldn't get rid of it if I had space to keep it... I am down to trade but your trade has to be special in all kinds of ways. Looking at Land Cruisers or LX470 mostly. Pick up trucks or full size 4x4s. I can add cash, or the trailer plus cash... Mostly I would prefer the cash.
#11 |
Not many people can get that much money off hand..banks wouldnt give a loan on such an old car. and if they could theyd buy a newer car..its a great build but your best bet is to part all the aftermarket put it back to stock silvia and sell it for 5k
#13 |
Yeah what he said except the go back to stock part. It will take some time to find a buyer with cash, usually the young and fan boy crowd cant easily come up with more than $5-6K for a car.
#17 | |
OP, don't acquiesce to defeat. Sell it for your price or not at all.
The mark of a true sucka: 'RARE JDM' & 'OLD LOGO NISMO'
#18 |
Thank you all for the interest,
No A/C as the current intercooler set up ( Mid-Mount) is where the A/C components used to be. As for trades I am willing to add cash, the trailer plus cash and even my 2003 TRD Toyota Tacoma 4x4 3.4 V6 ( worth $12K ) so total value would be well over $25K I am somewhat flexible on the price should you come up with cash. As far as parting it out I'm not really down. I really dont mind reducing the price $1,500 if you bring your own rims. Zilvia price $9K no rims.
#19 |
Let's see more offers guys. I would like for her to find a good new home. Mechanically it's solid as a rock. Aesthetically it could use a little TLC but nothing thats unmanageable, roofliner is USDM, easy fix as I have JDM S15 Seatbelts on her. Come see it and if you want a test drive its possible as well.
Call me or text 818-914-1sevenseven8
FRIENDS DONT LET FRIENDS DRIVE STOCK 1992 Coupe SE Last edited by driftertim; 05-02-2015 at 05:11 PM.. |
#23 |
![]() Join Date: Mar 2005
I'd post better pictures of it in its present state, with interior shots, and what cosmetic issues it has. Bump for coupes
Cool story Hansel....... |
#26 |
#27 |
Over 9,292 views, lets go Zilvians. I'm really not down to put it up on E-Bay.
#28 |
Dude it's too easy to buy shitboxes nowadays. Fuck. I want your seats but I can't buy a whole new car for them haha. GLWS.
#30 |
Let's see some offers, this car is ready for fun times with a new owner. It's a shame I have no time to use it.
FRIENDS DONT LET FRIENDS DRIVE STOCK 1992 Coupe SE Last edited by driftertim; 05-13-2015 at 01:02 PM.. |
brick headlight, drift 240sx sr20det, missile, power fc sr20det apexi, silvia conversion |
