Old 01-29-2015, 09:02 PM   #1
reaper_hkd
reaper_hkd is an unknown quantity at this point
#2 injector not firing!?!?
My car has been running fine forever at 405whp 399wtq outta the blue the #2 injector is not firing and can't figure out why?
reaper_hkd is offline   Reply With Quote
Old 01-30-2015, 01:42 AM   #2
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
How do you know it's not spraying? Try using noid lights to rule out the electrical aspect of it..otherwise ohm check the injector and look up the specs on Google.
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 01-30-2015, 07:10 PM   #3
Rusker
Rusker's Avatar
Rusker is on a distinguished road
I'm assuming you've pulled the injector to inspect it manually?
1990 S13/SR20
Rusker is offline   Reply With Quote
Old 01-31-2015, 01:48 PM   #4
Fuego
Fuego is an unknown quantity at this point
Have you tried swapping injectors around?
Fuego is offline   Reply With Quote
