Old 02-19-2015, 04:29 PM   #1
DEMo
DEMo is an unknown quantity at this point
2015 Budget VQ Swap
Hello Zilvia, I decided to make this thread after completing a third VQ swap. I built this car because I was tired of not getting seat time. I needed something reliable and comfortable. The VQ swap price rivals SR swaps with more bang for buck stock.
Powerplant:
2003 VQ35DE complete, 116K wrecked G35 sedan($800)
2004 Transmission, clutch line, OEM flywheel, FW bolts, clutch pressure plate ($400)
6 Puck Clutch($50)
Ebay intake kit ($36)
Shorten hard line ($0)
Cooling:
KA Radiatior w dual 12" fans ($130)
Silcone hoses ($60)
Adjustable temp fan switch ($20)
Swap Parts:
Custom drive shaft. G35 yoke with new S13 tail flange ($200)
Mount Kit. Ebay special is the biz and it comes with shifter bracket ($360)
Osiris license w NATS delete ($300)
Fuel System (tomei type S reg, z32 filter, brass T fittings) ($110)
Exhaust Y pipe to S13 out ($100)
Harness wiring: I did it myself ($0)
Power steering setup. Re-used stock SOHC setup ($0)
Vitals:
Asus memo pad 7 ($100)
Bluetooth OBD2 dongle ($20)
Torque pro for Android ($7)
Options:
Upgraded PS lines
Upgraded fuel system
https://farm8.staticflickr.com/7351/...c1fbb47d_c.jpg
Any questions?
Out with the old
retained AC
Instagram: @hexagarage for VQ S Chassis Parts
DEMo is offline   Reply With Quote
Old 02-22-2015, 09:17 PM   #2
Arrowking
Arrowking's Avatar
Arrowking is an unknown quantity at this point
I like that you found a way to keep the A/C! It looks like you had to modify the hood for it to shut completely? In fact, it looks almost like it has a bulge in the final pictures...
Arrowking is offline   Reply With Quote
Old 02-22-2015, 09:39 PM   #3
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Id do this swap if I owned another s car
Old 04-08-2015, 04:38 PM   #4
JaiDaJoker
JaiDaJoker's Avatar
JaiDaJoker is an unknown quantity at this point
Curious on how you retained ac. Did you just swap over the ka compressor and lines?
JaiDaJoker is offline   Reply With Quote
Old 04-08-2015, 08:05 PM   #5
nextproject
nextproject is an unknown quantity at this point
Most cases all you have to do is use the SWAPPED engine's compressor and have lines made. its not a perfect situation (different style compressors like different pressures etc etc, but luckily since both engines are nissan engines the VQ compressor should work just fine) but its far far better than no ac at all.
I plan on retaining ac w/ my vvti 1uz swap utilizing the toyota compressor and having lines made. all you need is the lines coming off the compressor that way a hydraulic supply shop can just cut them and make what you need. (my local hydraulic supply store will weld/braze custom ac lines for just about anything.)
nextproject is offline   Reply With Quote
Old 04-08-2015, 08:16 PM   #6
JaiDaJoker
JaiDaJoker's Avatar
Yea, i knew that was another option but was curious how he kept price down with getting lines made. How much does it run you locally?
Old 04-08-2015, 08:24 PM   #7
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Do any of your gauges work?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 04-08-2015, 08:31 PM   #8
JaiDaJoker
JaiDaJoker's Avatar
He's using the obd port with a dongle and the tablet to read everything through "torque"
Old 04-08-2015, 10:26 PM   #9
nextproject
Custom a/c lines shouldnt be more than 150 bucks. you take the ends off the VQ (or 1uz in my case) compressor, figure out how you need them routed, then take the ends off of where they terminate (one at the condenser, one at the evaporator i believe) and drop em off and VOILA new ac lines that should bolt right up!
Old 04-10-2015, 10:31 PM   #10
TurboTiger
TurboTiger is an unknown quantity at this point
I was wondering the same thing. I've done very little reading on VQ swaps.
TurboTiger is offline   Reply With Quote
Old 04-10-2015, 11:05 PM   #11
JaiDaJoker
JaiDaJoker's Avatar
hes using the obd port. but hes using a bluetooth obd2 adapter so he has to use a tablet. or phone. looks like this would be another great option for a quick approach to getting stock gauge cluster to work
http://www.dakotadigital.com/index.c...rod/prd825.htm
Old 09-28-2015, 02:14 PM   #12
DEMo
I cut the skeleton out above the plenum. There is a bulge but I prefer it over a spaced out hood.
SOHC KA compressor and lines were used. The KA AC bracket was welded to the VQ bracket and it uses the OEM tensioner from the the KA. Luckily, nissan uses the same belt size for KA/VQ
I bought fittings and 6' of hose and made the line myself. It was under $70 in parts for hi pressure and about $30 for low. I have since added a power steering cooler.
Fuel is the only thing that works. RPM works if you use a MSD pickup node. Speed works if you buy a GPS speedometer pickup from JEGS. wires right up to stock cluster. I cruise around with my tablet for my vitals. Torque lets you know whats going on in real time. I put my gauges away when drifting and peek at them after my run. so far so good.
https://www.youtube.com/watch?v=9ib9zDIa5E8
Old 09-30-2015, 09:09 AM   #13
ka-titties
ka-titties is an unknown quantity at this point
Nice work. I love my VQ S14. What final drive ratio do you have?
ka-titties is offline   Reply With Quote
Old 03-23-2016, 04:25 PM   #14
DEMo
Stock S13.
Old 12-10-2023, 09:10 PM   #15
GrimDrifter
GrimDrifter's Avatar
GrimDrifter is an unknown quantity at this point
Send a message via AIM to GrimDrifter Send a message via Yahoo to GrimDrifter
This looks like the guy that kept all my parts and money that i sent in to hexagarage years ago.
GrimDrifter is offline   Reply With Quote
