Old 08-05-2004, 02:12 PM   #1
fastbacchris
fastbacchris's Avatar
fastbacchris is an unknown quantity at this point
SOHC timing Q
I need to know where the 15 degree mark is on the pulley. I see 3 orange marks, and 1 circle groove. Can anyone tell me which one it is? Thanks in advance for the help...
fastbacchris is offline   Reply With Quote
Old 08-05-2004, 02:46 PM   #2
fastbacchris
bump anyone?
Old 08-05-2004, 03:00 PM   #3
Titan
Titan is an unknown quantity at this point
You will have 6 grooves on your crank pulley.
Starting from the left (going clockwise), the grooves will represent: -5, 0, 5, 10, 15, 20
So 15 will be the 5th groove from the left.
Sleep Doesn't Drink Beer
Titan is offline   Reply With Quote
Old 08-05-2004, 03:25 PM   #4
fastbacchris
are you talking about the holes one the pulley? if so how come mine only has 1 groove...
Old 08-05-2004, 05:02 PM   #5
Titan
I'm talking about the notches on the outer circumference of the pulley.
Why do you need to know? Adjusting timing using a light?
Old 08-05-2004, 05:24 PM   #6
fastbacchris
no im just tryin to get the 15 mark at tdc, is that all to it or am i missing stuff? If thats all to it, how do i rotate the pulley itself. Thanks for the info...
Old 08-05-2004, 07:52 PM   #7
Titan
Whoa, hold on here.
You want to set your motor to TDC? If so, 15 degrees it definatly NOT TDC.
For TDC, you want to have it at 0 degrees, and confirm that your distributor is positioned over the #1 spark plug wire.
Are you going to be taking the head or timing cover off? What are you trying to do?
You can rotate the pully by putting the tranny in neutral, and using a socket with an extension on the rachet to turn it over clockwise. The crank bolt is 27mm IIRC.
