![]() I have a couple problems. Its a 95 car with an s13 red top
My temperature is running high on the stock gage. I was told it should sit a little higher than my KA's but most people i talked to said it sits in the same spot. And i wouldnt worry about it but its the first day ive had the car back and the needle jumps all the way up. And second i did a tranny conversion. And my speedo wraps out when im only doing about 45. How do i fix it? And plus when im running in 4th and 5th gear the car kinda sputters. It wont go any faster. I think i was maybe doing a whole 50mph in a 70 today with the gas to the floor. Im new the SR i just picked it up from the shop today they said it should be okay and to take it easy for the first 500 miles. Im definately gonna give it back to them id just like to try to fix it tonight since its my only car and ive already been without one for a week. Thanks for any help |
![]() Join Date: Sep 2002
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
well you dont have ABS anymore b/c good luck wiring it to work again w/ the SR, as for the power loss check your intercooler piping...
89 240 SR powered... ummm i promise its stock ![]() |
#5 |
![]() Join Date: Mar 2002
![]() Feedback Score: 9 reviews
the temperature thing is due to not having the right sensor. have them swap the KA temp sensor into the SR (if they were competent, they'd have already done this). Are you saying you did AT/MT swap? If so, they're probably using the SR speed sensor. They need to use a KA speed sensor (from S13).
The sputtering could be due to the inaccurate speed signal causing the ECU to cut fuel, thinking you're doing over 110mph. |
