Old 08-08-2004, 11:26 AM   #1
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
Turbo bolts backing out how to fix?
Ok this is the third time i have had this happen to me in 2 yrs. I keep having the nuts back out that hold the turbo to the manifold, and the nuts/bolts that bolt the turbo extension elbow to the turbo. last nite i went out and drove a little bit. came home and had an exaust leak again. I havent looked to see which bolts are loose, or which ones fell off but I am 90% sure it is the manifold to turbo.
My question is, How do you guys make ur turbos stay on. I have tightend the bolts to 45ftlbs. hopeing that would cure but didnt seem to. I had to throw out the factory retaining clip deal that u bend to keep the nuts from turning, as it broke when i needed to take off the trubo. one side did at least. I placed the good one on the side where it is impossible to tightent the bolts when the turbo is installed on the manifold on the engine.
Is there any sort of high temperature locktite? I tried lock washers, they melt and become flat washers. Their is not enough stud length to place another nut to lock it in.
Please help as this is annoying.
Thanks,
Chris
autobahNESSA is offline   Reply With Quote
Old 08-08-2004, 12:24 PM   #2
Mr. Badlose
Mr. Badlose is an unknown quantity at this point
Send a message via AIM to Mr. Badlose
This is a somewhat common problem with SRs I've heard. When my turbo/mani gasket blew out, and it took a while to pull off everything and fix it. It's annoying how the nuts back out even with those retaining clips on there. If I have to do it again, I think I'll just have a tiny spot weld put on each nut.
Mr. Badlose is offline   Reply With Quote
Old 08-08-2004, 01:12 PM   #3
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Ya dude I think mine came loose again as well... #$%^&*(
There has to be some kind of high-temp lock washers we can throw on there that wont melt... Canton says stainless steel washers should be ableto handle it as they can tolerate like 2500 degrees or something close to it. Don't know if those cheapass Orchard washers we bought were stainless steel..
Badlose: If you put a little spot weld on the nuts how will you get it off? :P Cut it?
kazuo is offline   Reply With Quote
Old 08-08-2004, 02:32 PM   #4
Mr. Badlose
Mr. Breaker-Bar will be called in from the reserves. (the weld would be on the top of the nut, as to not interfere with a socket or open-ended wrench.)
Old 08-08-2004, 02:39 PM   #5
Blues13
Blues13 is an unknown quantity at this point
I used high-temp loctite on the threads when my gasket went out.. it seems to be holding up so far, its been a lil over a year now..
Blues13 is offline   Reply With Quote
Old 08-08-2004, 03:01 PM   #6
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
high temp locktite will usually burn off but its worth a shot if its all you got.
if they are the stud type, just drill them and use safety wire.
a weld would work but if you ever needed to take it off you will kick yourself hard.
Or you could buy some of those (expensive) bolts that have the allen head in the middle to expand them once they are in. They never loosen themselves.
andrave is offline   Reply With Quote
Old 08-08-2004, 05:24 PM   #7
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
use fucking high quality lockwashers before you put on the nuts, then tighten them down tight u might also want to use loctite with that but get lockwashers, oh yea and thos emetal clips that cme stock that are supposed to "hold" the nuts in place, throw that shit out!
same thing happened to me- ur gunna have to take ur turbo off, the two oil and two coolant lines and detach from downpipe to do this, also check to make sure your manifold bolts arent broken cuz that happened to me.
mike
sepulchral is offline   Reply With Quote
Old 08-08-2004, 05:34 PM   #8
sepulchral
and if lockwashers dont work than u have something seriously wrong, like bad vibrations or somethings shaking it loose.
Old 08-08-2004, 08:18 PM   #9
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
The nuts won't back out if you install the factory retaining plate properly.
Take the retaining plate, put it on, then torque the bolts down. Next, take a wrench (15mm should do the trick) that will fit over the retaining plate tabs that are next to the nuts, place the open end of the wrench over the tab/nut, then use a hammer to smack it down. The tab will start curving around the nut and will hold it in place.
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
Old 08-09-2004, 01:52 AM   #10
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
ok ill give you guys my story since i was just going to post this same question, i had this happen to me 50 times and i just kept tightening it with a wrench til the stud broke off one day haha so i took the whole turbo out and then replaced the studs, then like 4 months later my stock turbo went bad so i put in another one and now a month or 2 later the nut came loose again.....i have used red loctite and it works somewhat, but from what i have experience itsead of using copper nuts or shit you should use stainless steel lock washer and lock nut due to the fact they dont expand as much, basicly this shit is the most annoying thing about sr's i think....really it is im gonna have to tighten the nuts again tomorow lets hope the studs dont break again or im FUCKED
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 08-09-2004, 09:40 AM   #11
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
"Adam H" from Freshalloy had been battling this problem on his KA24E-T forever...and finally found a good solution:
That'll never blow out...hehe.
- Brian
orion::S14 is offline   Reply With Quote
Old 08-09-2004, 09:55 AM   #12
Bbandit
Bbandit's Avatar
Bbandit is an unknown quantity at this point
Send a message via ICQ to Bbandit Send a message via AIM to Bbandit
^^^ LOL
way to show those bolts whos boss eh?
==>>TGL GARAGE<<==.. RIP!
S13 coupe KA-T @ 0.5 Bar = SOLD!
A31 Cefiro + SR = Current
Bbandit is offline   Reply With Quote
Old 08-09-2004, 02:33 PM   #13
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
Chewing gum
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 08-10-2004, 01:23 AM   #14
andrave
andrave's Avatar
they make these expensive nuts that you can get at autozone (they are like 1 dollar each) that have metal at the top. so when you thread them down you crush the metal. thats what I'm using, hopefully they will work ok.
Old 08-10-2004, 01:02 PM   #15
NISMO_drift
NISMO_drift's Avatar
NISMO_drift is an unknown quantity at this point
Send a message via AIM to NISMO_drift
mine did the same shit when I replaced my turbo. ..Broke studs and everything. Get some stainless steel lock nuts... they look like a normal nut except the top is bent oval, which bites down on the studs...
92 White Pearl Sileighty
~S15 Front
~180SX Kouki tail lights
~S13 Blacktop SR20DET
NISMO_drift is offline   Reply With Quote
