Old 08-10-2004, 07:07 AM   #1
tastyratz
tastyratz's Avatar
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
Send a message via AIM to tastyratz
hatch release / gas release cable (s) I SEARCHED
ok guys i searched this already but i didnt seem to come up with anything useful to my question, all of them seemed to be people with cables that fell off. my gas tank and hatch have always been hard to pop since i got the car. If i want to pop my hatch i have to pull the lever and wedge something under it to keep the thing up. It only seems to release at the top of the levers travel. theres only 1 cable that goes into the little release bar thing however... my question is, is there any way to tighten that cable like you can tighten the ebrake cable? is there any place to kinda snug it up?
tastyratz is offline   Reply With Quote
Old 08-10-2004, 08:13 AM   #2
TheTimanator
TheTimanator's Avatar
hmmm, I have the same problem. I've never really tried to fix it though. Too many other problems... But I'd be interested if there is a fix for it.
Old 08-10-2004, 08:20 AM   #3
tastyratz
tastyratz's Avatar
theres gotta be... ive got about 1/8th of a gas tank and no way to get into it... this is a timebomb for me.....
Old 08-10-2004, 09:30 AM   #4
Andrew Bohan
i used to have to wedge something under the hatch release. i fixed that by adjusting the latch mechanism in the luggage area.
i dunno about tightening the cable tho.
Old 08-10-2004, 09:45 AM   #5
HyperTek
at least your lil plastic pieces at the gas tank cover didnt break... i had to rig up a replacement using zip ties... but my lever sucks too...
Keep it Classy
Old 08-10-2004, 11:32 AM   #6
DRO916
DRO916 is an unknown quantity at this point
Send a message via AIM to DRO916 Send a message via Yahoo to DRO916
same prob here, cant open the hatch by pulling, gotta go back and use the key and keep it turned to open the hatch...sucks
DRO916 is offline   Reply With Quote
Old 08-10-2004, 12:33 PM   #7
SlowCoupe
SlowCoupe's Avatar
SlowCoupe is an unknown quantity at this point
Send a message via AIM to SlowCoupe
i think i have a similar problem...is the hatch susspose to "pop" up when i pull the lever? i can open it using the lever but someone has to be pulling up on the hatch in order for it not to catch back on the lock when i let the lever go
SlowCoupe is offline   Reply With Quote
Old 08-10-2004, 12:38 PM   #8
tastyratz
tastyratz's Avatar
thats exactly my thing with the hatch part of it slowcoup, i have to jam something in there otherwhise it re-catches.
Old 08-10-2004, 12:46 PM   #9
Andrew Bohan
for all you guys who have trouble with hatch, try sliding the latch mechanism down a little bit (have to take off the trim panel). after years of use it can slide up, making it unable to release the hatch all the way.
the hatch should make a POP sound, but it will not physically hop off the latch like most cars
Old 08-10-2004, 06:07 PM   #10
DRO916
yeah in my first 240 i remember it poppin up when u pull the lever
koo i'll try that thanks
Old 08-10-2004, 06:46 PM   #11
SlowCoupe
SlowCoupe's Avatar
damn dude...you da man mr. driftaholic...i didn;t know y i did try that...i did that in my accord to stop the trunk from rattling...thanks alot man it work!!! now hurry up and finish your high compression ka!! hehe
Old 08-10-2004, 08:22 PM   #12
Andrew Bohan
awww shucks
Old 08-10-2004, 08:30 PM   #13
iknowyoulike
iknowyoulike's Avatar
iknowyoulike is an unknown quantity at this point
Send a message via MSN to iknowyoulike
I'll join the club on this one too. My 240 got the same flu....but like you guys pointed out i to have other projects goin on that's more important but this been buggin me too especially when my car is already running and i gotta grab something from the trunk for a friend and i have to shut my car...it's annoying ass hell..anyone with a reasonable solution? that has yet to be tried?
iknowyoulike is offline   Reply With Quote
Old 08-10-2004, 09:59 PM   #14
SlowCoupe
SlowCoupe's Avatar
try this...it worked on my 93 hatch...dunno how the coupe lock thingy works...give it a try
Old 08-10-2004, 10:13 PM   #15
Stock-S13
Stock-S13 can only hope to improve
I want pics....
Stock-S13 is offline   Reply With Quote
Old 08-11-2004, 05:28 AM   #16
tastyratz
tastyratz's Avatar
damn driftaholic i discovered that last night and couldnt wait to post it... why you gotta be the hero!!!! lol! yea that did the trick for me... i also bent the gas door metal piece a little bit and now everything is aok, thanks guys :-)
Old 08-11-2004, 02:11 PM   #17
amolao
amolao's Avatar
amolao is an unknown quantity at this point
Replacing the struts on the hatch will take care of the problem, too....
http://home.sw.rr.com/longstorenissan ***UPDATED 13 AUG 05 ***
amolao is offline   Reply With Quote
Old 08-11-2004, 08:21 PM   #18
projectRDM
projectRDM's Avatar
Same as a hatch, or any other car made. Adjust the latch downward, or raise the striker up. Takes 3 minutes.
FORMERLY R240NA
Old 08-11-2004, 10:41 PM   #19
SlowCoupe
SlowCoupe's Avatar
nope...did that first
Old 08-12-2004, 11:25 AM   #20
FallbrookS13
FallbrookS13 is an unknown quantity at this point
Send a message via AIM to FallbrookS13
heres what i did to fix the hatch problem.... if your hatch does not pop open anymore when u pull the lever.... or if you can hold the lever up and have someone else pull open the trunk this fix will work for you....
1. go the the hardware store and buy a spring about 1.5inches long and bout 3/4 inch diameter.
2. open your hatch and locate the rubber bushing that is in the left corner of the hatch....
3. remove this rubber stopper thing or find hte hold that it goes into if you dont have the rubber stoper anymore.
4. here is where you have options. you can either atempt to thread the spring into this hole or do like i did and weld hte spring to the hatch lid like i did. let me add that welding the spring works a lot better.
now your hatch will .... POP when you pull the lever and u will no longer be wedging stupid shit under ur lever to hold ur hatch up. in my situation my key did not work for my hatch so this was a huge headache ..... i actually got really limber and was able to hold hte lever from outside the car with my foot and then reach way back down the car and pull the hatch up...dont ask cause i have no idea how i used to do that .hahaha was a funny site to see.
hi.
FallbrookS13 is offline   Reply With Quote
