Old 08-17-2004, 05:48 PM   #1
Colorado S14
Colorado S14 is on the path to ruinColorado S14 is on the path to ruin
Greddy install questions
I received my Greddy turbo kit about a week ago and wanted to have those who have done the install look at what I have and try to tell me what I am missing. I took a bunch of pictures and fear that I may need some new hardware to complete the install. If any of my assumptions are incorrect please chime in and let me know. I have provided the following pictures to illustrate my parts I will draw reference to them throughout.
My biggest concerns revolve around the studs that came with the kit. I got 4 different types of studs. The number 1 are thick and long with a squared off center section. Number 2 is the same as the first but with a tapered center section. Both 1 and 2 have different threads on each end. Number 3 is shorter with the same threading on both ends. The number 4 studs (black ones) have a smaller diameter and do not appear to correlate with anything in the kit.
One of my fears is the manifold to turbo connection. I did not get any bolts and the studs that came seem to not be right for the job. The picture below shows the ends of each stud that will fit the nuts included in the kit, the nuts have the same threading as the mounting holes on the manifold.
This means that the only stud that can work to install the turbo to the manifold with the provided hardware is the short one, but they only included one of those studs in the kit. Now I could go purchase new nuts to thread over the different threads on the back of the long studs but they would bottom out on the center section show in the picture again causing problems. These are the number 1 studs.
So if those little studs are the ones I need I have 2 options that I can see. I can either call Greddy attempt to deal with their ****ty customer service, and order 3 more of those. Or I can try to find those studs locally or buy bolts that will work. What do you all recommend?
I am also curious about the metal spacers that came with the kit. I have 3 of them in 2 different sizes. 2 are taller then the 1 smaller one, I assume that one of these is for the spacer that is in the instructions for use on the oil pan. The spacers are part numbers 9 and 10.
Also what did you guys use the other parts on such as the black nuts (part number 16), the silver flat top bolts (part numbers 6 and 7), and the allen head bolts (part number 8)?
Thank you for all of the help guys you 5 minutes of typing may save me hours of install time.
Colorado S14 is offline   Reply With Quote
