Old 07-01-2015, 03:59 PM   #1
sileighty2jz
sileighty2jz is an unknown quantity at this point
Thumbs up 1988 nissan cefiro a31 1jz
text me at 703-864-8176
kevin.
1988 Nissan Cefiro A31
URL links at the end. it wont let me upload pictures -____-
Means of contact: PM
Price: $17,999 obo
Description:
Hey guys I'm selling my 1988 Nissan Cefiro that was imported thru Japanese classics llc and is 100% legal. The Cefiro came swapped from japan with an s14 sr20det in Japan but was recently replaced with a 1JZ. The car runs great with no issues what so ever as its my daily driver. The car is running off the stock ecu but does need a tune. A piggy back or some type of EMS will make this car even better. The car does have some rust on the rear fender wells but nothing major for its age. Frame rails are rust free and the paint still shines. The rear seats have been removed to accommodate an alumunium battery box but will be included with the sale. Below is the link from when the car was imported.
http://www.japaneseclassicsllc.com/1...urbo-sr20.html
Engine:
Rebuilt 1JZGTE
ARP Head Stud Kit 1JZ/2JZ
ARP Main Stud Kit 1JZ/2JZ
ARP Rod Bolt Set 1JZ/2JZ
ACL 1JZ/2JZ Race Bearing Set
1JZ NPR Standard Size Ring Set
1JZ/2JZ Front Main Seal
1JZ/2JZ Rear Main Seal
1JZ Valve Cover Gasket Set
1JZ-GTE (non-vvti) Exhaust Manifold Gasket
Heat Shielding Gasket - BOTH Upper and Lower Gaskets
2JZ-GTE Stock OEM Head Gasket
2JZ-GTE Water Neck Gasket
1JZ timing belt
1JZ Serpentine Belt - No AC Pump Installed.
1JZ/2JZ 90deg PCV Valve
1JZ oil pump
1JZ/2JZ/7M Oil Outlet Adapter Fitting With Crush Washer
1JZ/2JZ Thermostat
1JZ Denso Oxygen Sensor
1JZ TPS sensor
AZ Performance Oil Drain Flange for 1JZ/2JZ Oil Pan
AZ Performance T Series Turbo Oil Drain Flange -10
Custom engine and trans mount
Borg Warner S300 177275 Turbo
HKS style Tubro manifold
Tial 51mm BOV
Tial 46mm EWG with extra springs
NGK Iridium IX spark plug 6418 / BKR6EIX
K&N 4 inch Universal Filter, Short Version
Freed Enginering Custom v band downpipe
Freed Enginering Custom midpipe with Greedy axel back
Chase bays fuel lines
Walbro 255 Fuel pump
Alumunium radiator (came with car from japan)
HPS Radiator Hoses - Blue
Greddy R34 Intercooler using 2.75" Intercooler Piping
AEM Wideband
ARC Switch panel
1JZ Cam Seal (NON-VVTi)
1JZ Valve Stem Seal for Exhaust Side
1JZ Valve Stem Seal for Intake Side
Transmisson/Suspension/Wheels:
Dowel Pin For R154 And W58 Flywheel
R154 transmission
R154 OEM flywheel
Marlin Crawler Shifter Socket R154
Marlin Crawler Urethane Shifter Bushing For R154 Transmission
ARP Flywheel bolts 1JZ/2JZ
Spec Stage 2+ clutch
Custom power steering and clutch line
Freed Enginering Custom shifter extension for r154
Freed Enginering Custom driveshaft
Nismo Differential
Tiens Coilovers "super drift street coils"
5- lug conversion
New front wheel hubs
Z32 brakes all around with Z32 rear e-brake
Tien inner and outer tie rods
Custom s14 steering knuckles from japan
Konig SSM 18x9 +22 and 18x10 +15 "powder coated dark Chocolate brown"
Front tires have about 75% life left
Rear tires are brand new
Interior:
Driver side has a fixed Bride type Bucket seat
R32 seat for the passenger side
Nardi Steering wheel
Tomei Shift knob
Nismo shifter "Not short shifter"
Xplod CD player
Drift "buttion" for ebrake
New window motor for driver rear door
Alumunium recolator battery box. back seat "will come with back lower seat"
Exterior:
Car came painted pearl white from japan
Full ORIGIN body kit
Black Plasti dipped door handles
8K HIDs
LED blubs for the corners and lisence plate.
35% tint all around.
Pics:
""DEFI Gauges shown in the photos will not be included""
I love this car to death and I hate to sell it but I'm focusing on my career so my loss your gain. Please keep the negative comments to yourself. Thanks for looking!
https://www.flickr.com/photos/134354...7653003046833/
sileighty2jz is offline   Reply With Quote
Old 07-02-2015, 07:15 PM   #2
bansheeracer2003
Trader Rating: (28)
bansheeracer2003 is an unknown quantity at this point
Feedback Score: 28 reviews
Love a31 cefiro's
bansheeracer2003 is offline   Reply With Quote
Old 07-02-2015, 08:14 PM   #3
sileighty2jz
Thank you thank you!
Old 07-05-2015, 08:44 PM   #4
SidewaysTaco
SidewaysTaco's Avatar
SidewaysTaco is an unknown quantity at this point
free bump for fellow Cefiro owner, wondering what's next....
89' Nissan Cefiro
INSTAGRAM
SidewaysTaco is offline   Reply With Quote
1jz, car for sale, cefiro, jdm, nissan
