![]() I have a ka with 160k on it I know it's been drifted hard in the past and I haven't done a compression test yet but I already assume the worst.
My end goal is to reach 230-250whp on a T25 build. If the compression is bad is it easier and cheaper just to buy a used engine with good compression or rebuild the existing engine? If I do rebuild it I was planning to do a full factory rebuild with maybe like a metal head gasket and arp head studs because I think my end goal is reasonable for factory parts. |
![]() Join Date: Jul 2005
budget 5k for a typical sr swap and call it a day. Why mess with murphy's law? Buy local after a compression test, and have everything ready to drop it in the instant you get it (it should only take 1-2 days max. It takes me about 8 hours now, in AND out) so if it starts up knocking you can complain and take it back, most places honor their engine's "startup warranty" for 30~ days.
KA engine is a great reliable beast, but god help any novice non-mechanic that trys to turbocharge one. The same shall Forget about opening it up, even with his help. |
It'd be cheaper to rebuild in the longrun for that power level. It only took me $2500 to completely rebuild the last KA I did with nismo mounts, arp studs, acl bearings, oem parts. A turbo kit might bump up the cost a bit. SRs are cheap but by the end of completing the swap youd be in the same cost as rebuilding and turboing the ka.
Im selling a whole built sr20 swap for $6k. Engine, trans, wiring, tuned haltech, twin scroll GTX3076r. Full build pictures and reciepts available. Just another option that might save you some $$$ in the longrun. |
#5 | |
"Simplicity is the key to brilliance." - Bruce Lee |
