Old 08-21-2015, 08:02 PM   #1
FutureFab
Trader Rating: (32)
FutureFab is an unknown quantity at this point
Feedback Score: 32 reviews
1jz Vvti Compound turbo S13
Sold Sold Sold
Sold
Track ready S13 240 1jzgte vvti swap with Compound Turbo kit and V mount setup.
Very responsive power!
Engine runs great! Just compression tested and its 180psi across all 6 cylinders!
Build thread..http://zilvia.net/f/showthread.php?t=525272
First two pictures are before the V mount was done with a new Garrett 700hp core and Griffen triple pass radiator.
Jzx100 1jz vvti swap w/5 speed R154 transmission,
Spec stage 3 clutch,
ARP flywheel bolts
R154 rebuild kit w/syncros and bearings,
Marlin Crawler billit 1-2 shift fork,
Marlin Crawler bearing plate,
Marlin Crawler thrust washer,
Drift motion billit 3-4 shift fork,
Drive shaft shop aluminum shaft,
FutureFab Swap mount kit,
Map sensor based Powerfc,
Hondata 4 bar map sensor,
6x 1000cc Injector dynamics,
Avcr boost controller running small turbo,
Pfc boost control kit running big turbo,
430 e85 pump,
-6an fuel lines front to back,
Aeromotive fuel regulator,
Tial 50mm bov,
Tial 60mm gate,
Tial Mvr 44mm gate,
Garrett Gt4202r ball bearing turbo,
Drift Motion upgraded Ct15 small turbo,
4" stainless downpipe,
3" stainless side pipe,
Garrett intercooler,
Griffen triple pass radiator,
AirRaid filter,
B&N Oil cooler,
Mocal oil thermostat,
Tomei cams,
Titan V2 cam gear,
Painless switch panel,
5 lug,
4 5zigen Fno1rc 17x10 wheels,
2 17x9.5 Work wheels,
R32 Gtr brakes (bigger than z)
Nismo power brace,
S14 Rear subframe,
3 different rear diff gear sizes (350z 3.3 Q45 3.7 GTR 4.1),
Gk tech rear knuckles,
all suspension links w/ heims,
Dmax vented fiberglass hood,
BC coilovers,
Gtr diff,
Gtr axles,
Gtr hubs,
Voodoo Cnc front tension links,
FutureFab extended Flca,
FutureFab angle knuckles,
FutureFab modded front cross member, FutureFab rack spacers,
Circuit sports extended tie rods,
Silvia front w/bricks and corners,
Suspicious brake line tuck kit,
Pathfinder BMC
misc brand guages,
Full Roll cage,
Sfi spec cage foam,
Frame braces,
Optima battery,
new Timing belt,
new Timing tensioner,
new Timing idler,
new Front and Rear Main seals,
new Cam seals
New water pump all 2 years ago.
Wink Braudview mirror,
Corbeau bucket seat with Racequip harness,
Spare driver door,
Spare axles,
Then all the labor to put that stuff together. Probably forgetting some stuff too.
This is a track car built to have fun with!
I understand paint and body isnt clean and spiffy. I couldnt justify doing such things with the possibility of hitting other cars or tire walls.
$11,700 Obo takes this running car and spare parts!
Clean Az Title!
Text 602-738-2593 if seriously interested
futurefabrication.com
FutureFab is offline   Reply With Quote
