Old 08-29-2015, 07:05 AM   #1
bucket 240
bucket 240 is an unknown quantity at this point
CA supercharged ls1 s14
Motor: chevy ls1 stock bottom end clevite racing bearings main and camshaft rings gapped heads: arp head studs metal gaskets, springs, push rods,retainers,valve seats the whole valve train has been upgraded using comp cams with an ls9 camshaft ls7 hydraulic rollers a millen ported oil pump double roller chain from spl a flyudine hermonic balencer oil cooler ls2 front cover motor swap kit sikky.
Magnuson superchager dynoed on 5lbs making 440hp and 450tq custom intake manifold water to air incooler 80lbs injectors cx racing fuel rails aremotive fuel pressure regulator 2 255 walbor fuel pumps
Transmission t56 with 1-4 just rebuilt with billet gears rear end stock with stock gearing
Suspension feal coilovers all the rear arms power by Max with thier drop knuckles solid subframe bushings. the front arms are custom extended an inch the knuckles were shorten power by Max inner tie rods with spl outers brand new power steering rack with power by Max eccentric bushings.
Breaks: the front z32 front discs with z32 calipers. the rear z32 discs with z32 calipers asd hydro e break hooked up to z32 calipers 6 point Dom cage with door bars bride bucket seats 4 point harnesses that is as much as I remember right now. No trades. 13k this week only call or text 6614926740
File Type: jpg top-drift-round-2-luke-munnell---046.jpg (55.9 KB, 185 views)
bucket 240 is offline   Reply With Quote
