Old 08-27-2004, 04:22 PM   #1
TurboB15sentra
TurboB15sentra is an unknown quantity at this point
Send a message via AIM to TurboB15sentra
Dyno charts and info from my drag car.. :)
For those who don't visit Fresh Alloy.. and didn't see the charts.. I brought my S13 to the dyno on Monday this week. I ended up having rear end problems (pinion bearing), and couldn't finish tuning it at high boost.. The last pull we made.. was 26psi and a 75 shot. The rear end was making so much racket.. I let off of the gas at at around 5500rpm. Power was already at 512whp and 480ft lbs. The other pull on this chart... was around 13-14psi and a 75 shot. We made a bunch of other pulls.. but these are the only two I have.
The car made 380whp and 312ft lbs at 1 bar without the nitrous as well... I'll be fixing the rear end.. and I have a S13 head I'm putting on with a Greddy short runner manifold. I think that will allow me to make even more power at lower boost levels.
Travis
www.fi-r.net
Nissan Performance
TurboB15sentra is offline   Reply With Quote
Old 08-27-2004, 04:24 PM   #2
TurboB15sentra
Here's some finished pics of the car...
www.fi-r.net
Nissan Performance
Old 08-27-2004, 11:05 PM   #3
DRFT180
DRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud of
Where exactly do you live? I've never seen your car. Is it just a drag car?
DRFT180 is offline   Reply With Quote
Old 08-28-2004, 07:48 AM   #4
98sr20ve
98sr20ve is an unknown quantity at this point
Travis, What are the stats of the car and turbo. Impressive numbers BTW
98sr20ve is offline   Reply With Quote
Old 08-28-2004, 11:34 AM   #5
NiZMo1o1
NiZMo1o1 is an unknown quantity at this point
Whoa very impressive , are you expecting 9s ? or even lower?
NiZMo1o1 is offline   Reply With Quote
Old 08-28-2004, 01:29 PM   #6
Ritz S14
Ritz S14's Avatar
I bet if you didn't have a headrest at about 4,400RPM that boost would snap your neck.
Ritz S14 is offline   Reply With Quote
Old 08-30-2004, 01:30 AM   #7
TurboB15sentra
I live in Houma, Louisiana.. about 35 miles southwest of New Orleans. Pretty much on the coast... I had posted pics of the car's progress several months ago. I finaly got it finished though.. Took me about 6 months. I run a speed shop, so I don't always have a lot of time to work on my own stuff.. Here's a rough list of the main components in the car..
S14 SR20DE block/head/tranny (non-turbo)
JE 8:1 pistons
Saenz forged rods with ARP bolts
Cometic metal headgasket
ARP headstuds
Nissan Motorsports heavy duty main bolts (Pulsar GTI-R)
Nissan bearings/seals
HKS 264* cams
HKS valvesprings
JWT flywheel and Z32 clutch/pressure plate
Slight bowl work on the head
FI-R log manifold (1.5")
3" downpipe
2" dumptube
50mm wastegate
T61/P-trim turbo
Greddy Type R
2.5 and 3" piping
Griffin core with custom end tanks (intercooler)
3 ply silicone with double clamps
NOS Direct Port fogger nitrous setup
Twin Walbro 255lph pumps
Dual feed billet fuel rail
Aeromotive regulator
Stainless steel twin -6 feed lines
Electromotive TEC II standalone engine management
1150cc injectors
Apexi AVC-R boost controller
Welded stock diff
15"x9.5" slicks
15"x 9.5" custom Bassett Rims
I am putting a S13 head on the car and a short runner manifold. The S14 head/stock manifold is holding me back big time. I might also switch to a SC63/T4 turbo. SHOULD go 9's once I get my cage in. I'm not even driving it until it has a cage in it. I can actually say... I am scared of this car.
Travis
www.fi-r.net
Nissan Performance
Old 08-30-2004, 11:51 AM   #8
BSeay
BSeay's Avatar
BSeay is an unknown quantity at this point
Send a message via AIM to BSeay
Nice job dude!
1995 240SX SE - Sold
BSeay is offline   Reply With Quote
Old 08-30-2004, 06:39 PM   #9
nissantuner22
nissantuner22's Avatar
Trader Rating: (-1)
nissantuner22 is on a distinguished road
Feedback Score: -1 reviews
Send a message via AIM to nissantuner22
Big ups for using an SR20DE block. Well done travis!
Current Project: Operation: N/A SR: 93 Silvia Q SR20DE Engine with go fast goodies. ,
"Common problems 240sx's suffer from are curbs, trees, ditches, and other immovable objects."thx247
"on the tounge... there is no guardrails."- citizen
nissantuner22 is offline   Reply With Quote
