Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 10-19-2015, 10:38 AM   #1
RussellM
RussellM's Avatar
Trader Rating: (57)
RussellM is an unknown quantity at this point
Feedback Score: 57 reviews
DEATSCHWERKS DW350iL In-Line Fuel Pump | NISSANPARTS.CC
DEATSCHWERKS DW350iL IN-LINE FUEL PUMP
Part Number: 9-350
350LPH
DeatschWerks is excited to officially release the newest member of their world renowned fuel pump line, the DW350iL. This High Flow, 350 liter per hour fuel pump is DeatschWerks’ first externally mounted in-line fuel pump, expanding its line to continue as one of the most comprehensive in the industry.
The DW350iL will be the highest flowing pump DeatschWerks has offered to date. Flowing 350 LPH @ 40psi and over 300 LPH at 70psi, it can support over 750hp. Utilizing roller-vane technology allows a flatter flow curve, which means more flow at higher pressures - a must for turbo and supercharged applications.
Along with higher flow rates, the DW350iL comes with -8 AN ORB female fittings on the inlet and outlet to easily incorporate larger fuel lines, an anodized aluminum body, two t-bolt mounting brackets with rubber isolators, and rubber boots to protect the power terminals.
The DW350iL has been engineered to fit Bosch 044 surge tanks, which provide reserve fueling capacity and dual pump capability - important in many high power motorsport applications.
http://nissanparts.cc/partlocator/in...catalogid=9759
RussellM is offline   Reply With Quote
Old 10-19-2015, 12:46 PM   #2
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
nice pump!
I might consider purchase
Dboyizmlg is offline   Reply With Quote
