![]() my s13's running taillights, brake lights, and rear signals went out but the fuses are all good and the dash lights are still good. need help finding the problem.
![]() Join Date: Aug 2008
Check the switches behind the steering wheel. I had disconnected my hazard lights switch/button while chasing down an electrical problem at one point and noticed the same issue (in the driveway and not on the road thankfully). If the switch is bad, that could be your culprit.
Try the infamous combination switch replacement, you can order one at auto zone or car quest.. Otherwise if you search there is a tutorial how to fix, but it didn't work for me I had to buy a new switch anyways. Check where your brake switch is and make sure there is a rubber stopper (you can find them at the dealership they are green about the size of a nickle and go on the front of the brake pedal assembly directly aligned to the center of the break switch button on the metal part you'll see 2 holes one is cruise control the other is your break switch. Hope that helps.
![]() Join Date: Feb 2011
![]() Feedback Score: 12 reviews
Check you tcu behind your driver side kick panel. It is a small white box. Check the little circuit board in there and if there is any burn traces, look for the thread on how to fix it with a jumper wire.
Leaks,Creeks,Squeaks, and other random problems. Yup you own a 240. ![]() |
lights, s13 |
