![]() Join Date: Apr 2007
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
★★★ Fortune Auto Custom Coilovers! THMotorsports Is Fortunes #1 Dealer! ★★★
![]() Fortune Auto makes some of the best full coilover systems on the market today. Unlike most other brands that are all made in the same factory in Taiwan, these have been designed, tested, and hand built in VIRGINIA. Each unit is BUILT TO ORDER and take 3-4 weeks to get shipped to you. Custom spring rates are available for most models. ---------------------------------------------------------------------------------------------------------------------------------------------------------------- Fortune Auto 500 Series (Daily occasional track use) ![]() Fortune Auto 510 Series (Track use) ![]() Fortune Auto Dreadnought Series (2-way/3-way external reservoir) 2-Way ![]() 3-Way ![]() Muller Air Cup System ![]() Air Bag-less system Offering the convenience of a conventional air bag system without the loss in performance, Müller air cup lift systems slip on the shaft of our coilover assemblies. The lift system compresses the spring and extends the shaft to lift a lowered vehicle one to two inches. Once the air cup is fully purged of its air, the cup merely acts as a metal spacer. No loss in performance or ride quality is experienced since the air cup has no moving parts when purged. The Müller system can be used on race cars to allow navigation over high slung trailer ramps. This allows a very low vehicle to navigate safely over speed bumps, inclines and any other obstacle on the road. Müller air cups can be ordered in one and two-inch stroke configurations. Coilover applications with minimum available stroke can only use a one-inch stroke air cup. Other applications that have longer shocks and piston shafts can run our one or two-inch stroke air cups. Müller air cup lift systems are designed to lift a vehicle temporarily over obstacles. They are not intended as an air bag system to drive around when aired up. The seals in the air cup can sustain aired-up driving; however, when the air cup is full of air the coilover springs are compressed. This effectively doubles the spring rate of the spring and ride quality will suffer. We recommend that this system is used exclusively to assist a lowered vehicle over an obstacle. Müller air cup lift systems are designed and made in the USA. All systems are made of aircraft grade 6061 T6 aluminum, Teflon seals, and high quality o-rings. Müller air cups are extremely durable and can be used on race vehicles. A one-year warranty is provided with every system which can be serviced at our North American facility. Müller air cup lift system details: Proudly made in the USA Designed in the USA with the latest CAD programs Forged 6061 T6 construction Anodized for corrosion resistance and strength Extensively tested for trouble free operation Serviceable in the USA Compressor system details: Rugged VIAR compressor 2 gallon VIAR air tank Integrated mounting plate Paddle valve used for airing up and purging system Pressure switch relay Air pressure gauge DOT approved air lines All necessary installation hardware Müller Air Lift Cups on Fortune Auto Coilovers Demonstration on Vimeo NOBODY WILL BEAT OUR PRICES! Phone - 800-959-0145 ext 102 Email - [email protected] |
