Old 12-16-2015, 08:10 PM   #1
Makstraw
Makstraw is an unknown quantity at this point
90 S13 Coupe, SR20DET READY!!!
CAR IS SOLD! Look For New Post for SR20DET Partout!
*Before You read below, Lets keep this simple. If you like to smash your POS into walls and you don't have any money to spend, then this isn't for you. This car is for someone with a couple bucks, who can appreciate nice things. That being said, If you have an opinion, keep it to yourself. Read the bold sections.*
Price is $4500 with everything. It is ready for another SR20 in its current state at this price. All you will need is a SR20, Trans, ECU radiator and overflow. Its all wired, and all supporting pieces included. If you want the shell minus the SR20 stuff, we can talk that price if your a serious person. PM me for more details.
1990 Nissan 240SX Coupe XE:
-Clean Florida Title
-Manual windows, locks, no sunroof
-Complete AC system included
-Heat works
-Repainted AH3, Nissan Cherry Pearl
-NewTrunk Carpet
-New rear deck carpet with 3rd brake light and speak delete
-Engine bay shaved, sanded and refinished in gloss black
-Headliner refinished in black
-New Dash Overlay installed. Looks factory
What’s Included
-Walbro 255LPH fuel pump
-180sx LSD differential
-Tein inner tie rods
-Tein outer tie rods
-Isis Pro coilovers
-Isis RUCA
-Isis traction rods
-Nismo Power brace
-Powered by MAX solid steering rack bushings
-New Nissan steering rack (July 2014)
-Isis rear toe rods
-Isis tension
-Q45 front brake calipers
-Altima 11" rear brakes
-SS brake lines
-17x9 & 17x10.5 Mustang Cobra Reps (215 45 front, 245 40 rear)
-Almost new Federal 595 tires up front
-New Toyo tires in the rear
-Fresh Alignment
-New S14 5 lug swap (January 2014)
-Circuit Sports red and clear tail lights
-Rolled and pulled front fenders
-Rolled and pulled rear
-Pig nose lip
-Brand New redtop Optima Redtop
-New Sparco Steering wheel
-S14 manual seatbelts conversion
-Clean S14 seats installed
-NRG Short hub
-Autometer gauge oil psi
-S13 drive shaft
-Clear JDM Turn Signals/Markers
SR20DET Parts
-Wiring Specilties S13 to S13 SR20DET Wiring Harness (Includes Igniter chip and coil packs)
-New SR20 Water Pump
-New thermostat
-New SR20 Cold Air intake w/ New Filter
-New Z32 Fuel filter
-New OE COMPLETE SR20 gasket set(Includes entire engine gasket set)
-New ISR Long steel braided clutch line(From Master to slave)
-ISR Braided Bottom mount Turbo Lines(Complete)
-ISR Water Line from neck
-New S14 water neck
-New ISR Poly urethane Engine Mounts
-Greddy Intercooler set(Complete w/ hoses and couplers)
-HKS SSQV BOV
Makstraw is offline   Reply With Quote
Old 12-17-2015, 10:29 AM   #2
Makstraw
Seeing a ton of interest at this price. It is still available. This is a great platform to build on.
Old 12-17-2015, 08:50 PM   #3
Makstraw
CAR IS SOLD! Bump For New Post with SR20DET Partout.
