Old 12-21-2015, 08:33 AM   #1
Dempseybe
Dempseybe is an unknown quantity at this point
Possibly blown KA24DE?
Hey guys, so I picked up a 92 s13 hatch with a rebuilt KA24DE with about 7200 on a fresh rebuild.
Car runs flawlessly except a minor coolant leak on the hose connected to the throttle body. We fixed the leak(thought so atleast)
Well, was on the interstate on my way to work. Car running great, all of a sudden notice a loss in power, first instinct is to look at tempature and sure enough it's over heating. Put it in neutral and go to the emergency lane and it stalls the minute it is out of gear. I allow it to cool down naturally and I insert coolant into radiator and try to start it. The belts and pulleys spin, but it sounds like absolutely no compression. Grabbed my compression check and checked compression in #3 and it read 0
Pretty much all I hear is a starter spinning and no sound of the motor compressing. Will do a more thorough compression check when it is home.
Dempseybe is offline   Reply With Quote
Old 12-21-2015, 09:43 AM   #2
Dempseybe
Could use some feedback guys
Old 12-21-2015, 10:19 AM   #3
RickBlaine
RickBlaine's Avatar
RickBlaine is an unknown quantity at this point
How much coolant did you have to add to the radiator? Don't say "a little" or "not much". Please try to quantify it....
A friend had a timing chain snap- with NO sound or rattle. It just went.
Did you check your oil level? Any contamination?
1991 Nissan 240sx Fastback - BLACK
104K miles June 2016, Auto trans
RickBlaine is offline   Reply With Quote
Old 12-21-2015, 10:32 AM   #4
95_S14
95_S14's Avatar
Trader Rating: (108)
95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future
Feedback Score: 108 reviews
you can wait more then 1hr and 15 min for people to get back to you
Www.PowerAutosports.com
95_S14 is offline   Reply With Quote
Old 12-21-2015, 10:32 AM   #5
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Give us some feedback on the other 3 cylinders. Jeez.
Have you bothered to look at your coolant and/or oil to see if it's mixed w/ the other?
You give us the run down of what happened but did you bother to check the basics first before starting this thread?
I like my bikes how I like my b¡tches...naked!
2014 Triumph Street Triple
kruked is offline   Reply With Quote
Old 12-21-2015, 11:02 AM   #6
Dempseybe
I wasn't rushing. Was just adding that I'm looking for feedback. I couldn't do a check on the other 3 because the spark plug boots seperated from the plastic and was lodged in the sockets. The oil was darker than normal but not milky in anyway. The radiator was dry. But with the engine not making any sounds of combustion I didn't finish filling it up. So I'm assuming the radiator was empty. (The heat may have evaporated the rest)
Old 12-21-2015, 11:03 AM   #7
Dempseybe
Once I tow it home I will be pulling the valve cover off to see if the chain snapped. Or if the valve is stuck open.
Old 12-21-2015, 11:05 AM   #8
Dempseybe
Oh and to add to all of that. The pulleys are all still spinning, it seems to me that the engine isn't seized up, just isn't compressing. Any advice on other things I could check to see why there isn't any compression in that cylinder? If it were just a head gasket wouldn't I be seeing some sort of compression? Maybe a low 15 psi or less?
Old 12-21-2015, 11:27 AM   #9
KAT-PWR
KAT-PWR's Avatar
0 comp sounds like it's done
My piston with a brutal hole in the ring lands read 0, cyl 3 had the same thing but not quite as bad and I got 50psi (you can see said motor in my build thread)
Valve issues?
Unless it's something retarded like the chain broke but I have never seen that, not saying it can't happen but I've never seen it.
If I saw 0 comp I'd pull the motor out. Or if you wanna pull the head if a borescope is not available.
MRP Manufacturing
Old 12-21-2015, 11:54 AM   #10
Dempseybe
Once I get it home I'll be able to update what the valve and chain situation is in. I'll keep you guys updated
Old 12-21-2015, 12:24 PM   #11
Dempseybe
I'm about to say screw it and just buy an rb25det. #madskidz
Old 12-21-2015, 02:02 PM   #12
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Next time pick one spot and post there. Also use the edit button to add on to your prior post.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 12-21-2015, 02:41 PM   #13
Kingtal0n
Kingtal0n's Avatar
freshly rebuild with 7500 miles... sounds about right
Old 12-21-2015, 04:49 PM   #14
jedi03
You can see if the piston is moving up and down with a light too
Old 12-21-2015, 08:01 PM   #15
Dempseybe
Ok so I got it home, and pulled the plugs but the end of the wire boots melted to the socket. So I spent an hour and a half digging it out of cylinder 2. Ran a compression test and got 0 on #2. To save myself the trouble of getting #1 and #4 out I think it's safe to say they will read 0, and I'll pull the heads. The valves seem ok. I watched them all compress and depress with the cams moving. So maybe just a blown head gasket. I'll see once the heads are off
Old 12-21-2015, 08:39 PM   #16
KAT-PWR
KAT-PWR's Avatar
I'm going 80-20, 80% chance the skirts are blown out
MRP Manufacturing
Old 12-21-2015, 09:33 PM   #17
fatduece
fatduece is an unknown quantity at this point
Sell the Ka to some hoonibro. DONT GET THE RB. It already gets enough bad rep from people that blown it up without doing any research. Get a 1j/2j.
fatduece is offline   Reply With Quote
Old 12-21-2015, 09:50 PM   #18
kruked
Trader Rating: (37)
Originally Posted by fatduece View Post
Get a 1j/2j.
More cylinders equal more problems. Can you imagine the OP w/ more cylinder problems? I mean shit, he started this useless thread for some "ideas" after he already knew that he had 0 compression in cylinder #3. It's not rocket science to just go ahead and check at least 1 more cylinder for compression to satisfy my taste.
Old 12-22-2015, 05:24 PM   #19
fatduece
He's just a dreamer! Lol.
Old 12-22-2015, 05:30 PM   #20
JAStirrett
JAStirrett's Avatar
JAStirrett is an unknown quantity at this point
Who rebuilt the motor, geez.
The addiction is real...
JAStirrett is offline   Reply With Quote
Old 12-22-2015, 05:47 PM   #21
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Three littles?
Old 12-22-2015, 08:12 PM   #22
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
When I first saw this thread posted I thought to myself "boy, you would have to do something REALLY STUPID to blow up a KA". As it turns out I was right. I don't even get the point of the thread. I mean, if you KNOW you have 0 compression what possible advice could you expect from us? There is no miracle solution to 0 compression. Tear the engine apart and see what you screwed up with your ignorance.
Dropping an RB in is a GREAT idea, I say go for it. Then we could start a pool for how long it will take you to overheat the crap out of it and cook that one too. Since RB's in S-chasis are notorious for cooling issues, it shouldn't take long.
Also, delete your coolant temp gauge for weight savings. It seems you never bother to look at it anyways!
Old 12-23-2015, 03:26 PM   #23
cotbu
cotbu's Avatar
You know how much boost you can run with zero compression?
Not enough![emoji24]
Old 12-23-2015, 04:36 PM   #24
jumboflan
jumboflan's Avatar
jumboflan has a little shameless behavior in the past
. Did you see the temps rise? Did you have water radiator fluid in the car? You could've turned the heat all the way to high. And prevented head gasket failure
Im immune to bullshit....so put your shovel away.
jumboflan is offline   Reply With Quote
Old 12-24-2015, 06:07 PM   #25
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
my experience with KA's is once they over heat, its a warped cylinder head maybe more especially if its losing power and dieing after overheating
The excessive heat could also cause the rings to expand and if there wasnt enough end gap on the rings this could force them outwars into the cylinder walls causing some cylinder and ring damage
how far up did the temp gauge go? regardless the cylinder heads gotta come off at the least if you have no compression
pretty much what everybody has already said just giving a +1
kyral is offline   Reply With Quote
compression, head, ka24de, rebuild
