02-13-2016, 04:28 PM | #1 |
2JZGTE Toyota Cressida Drift/Street Car Caged Standalone e85 650whp
SOLD SOLD
Asking price: $14,500 with the weds $11,500 without the weds Contact name: Tony Contact number: 318-751-3323 Parts/Mods list: engine: Aristo 2JZ-GTE Head Supra 2JZ-GE Block (No oil Squirters) OEM GTE Rods OEM GTE Pistons New OEM Timing Belt New OEM Tensioner New OEM Thermostat New OEM PCV Valve New OEM Gaskets, Seals New OEM MKIV Water Pump & Housing New OEM MKIV Radiator Hoses New OEM Oil Pump ACL Race Main Bearings ACL Race Thrust Bearings ACL Race Rod Bearings DM Power Steering hose DM Nuts and Bolts ATI Super Dampener Underdrive pulley NGK BKR7E Spark Plugs Custom Intake Manifold Q45 Throttle Body Power Steering Cooler JZX81 Engine Mount Brackets Ultra Urethane Motor Mounts IS300 Aluminum racing Radiator USDM intake Cam (7hp) Polished Valve covers Polished Intake Manifold Fuel Delivery: Injector Dynamics 1000cc Injectors Twin Walbro 255 Pumps HKS Dual Feed Fuel Rail Aeromotive FPR DM FPR Gauge DM Fuel Bypass Hose Russel In-Line Fuel Filters Summit -6AN Fittings Summit Adapter Fittings Summit -6AN SS Hose Turbo Gear: Precision Turbo Equiptment 6266 t4 single scroll .84a/r Tial 44mm Wastegate T4 Reinforced Tubular Exhaust Manifold 3" Downpipe 3" Straight pipe 5.5" Duramax Exhaust Tip 4" Intake K&N Filter 3" Aluminum Intercooler 3" Aluminum Piping Silicone Couplings T-Bolt Clamps Kaizen -4AN Feed Line WFD -10AN Return Line Earls Fittings T4 Turbo Blanket 3" V-Band Clamps Drivetrain: R154 3" ShaftMasters Drive shaft Xcessive Manufacturing MK3 Supra Diff Swap kit Comes with 2 differentials 3.73 LSD w/a locker 3.73 LSD w/Weir shim kit Reinforced Subframe JZ Bellhousing DM Lightweight Flywheel ACT EXTREME PP ACT 6 Puck Clutch ARP Flywheel Bolts MCrawler Shifter Bushings MCrawler Shifter Socket DM Full Clutch Hose MKIII Clutch Master Cylinder MKIII Clutch Pedal Assembly New OEM Slave Cylinder New OEM Clutch Hub New OEM Throw Out Bearing / Pilot New OEM Clutch Fork New OEM Fork Support New OEM Nuts / Bolts Redline MT90 Gear Oil ES300 Throttle Cable Remanned and Upgraded Alternator Electronics: ECU Master Full Standalone Computer ECU Master Oil pressure gauge ECU Master Fuel pressure gauge ECU Master Bluetooth adapter ECU Master boost controller 2 Tunes, Pump gas and E85 No gauges in the car Samsung Galaxy Note 10.1 inch Tablet This tablet and the bluetooth adapter displays all of the gauges New OEM Connectors Suspension/Wheels/Brakes: Weds Kranze Bazreia 19x10 19x11 American Muscle Mustang Bullitt Wheels 18x9 18x10 2 XXR 2 MB Battles Megan Coilovers T3 Roll Center Adjusters Xcessive Manufacturing Front Lower Control Arms Xcessive Manufacturing Outer Tierods Xcessive Manufacturing Tension Arms Xcessive Manufacturing Steering Arms Xcessive Manufacturing Toe, Camber, and Caster Rear control arms Xcessive Manufacturing Dual rear caliper brackets Remanned MX73 PS rack Beech 300zx brake Adapters Extended Lug Studs 30mm Aluminum 300zx Calipers Drilled/Slotted Rotors Stainless steel braided brake lines Summit Battery Relocation Kit Rear Access Battery Cut off Switch Dragonball Shift Knob Nardi Classic 165mm Leather 6K Hi/Lo HIDs Awesome Broadway Rear View Mirror Authentic Bride Lo-Max Seats Sparco 4pt Harnesses 6pt cage built to FD specifications Full interior in the front except carpet Painted cage, bed liner on the floors Rear Bumper bash bar Cresta JZX81 Front bumper Last edited by pelliccio77; 05-05-2016 at 05:31 AM.. Reason: SOLD |
02-13-2016, 05:33 PM | #2 |
Is it just me or did a bird shit all over the cage ? Them welds tho . Other then that looks ok glws
Www.PowerAutosports.com |
02-14-2016, 07:52 AM | #6 |
02-25-2016, 06:28 PM | #14 |
Sick man. If I could get close to that out of my 1jz single Datsun s30, I would be all over this. You firm on the price?
Sent from my SAMSUNG-SGH-I537 using Tapatalk |
03-04-2016, 02:53 AM | #21 |
GTO's are cool but I need cash so it'd have to be something relatively stock that I could flip with one exception. I would trade for a Silvia front coupe with style and an sr with some cash on top
03-14-2016, 04:24 AM | #22 |
Well I have a stock GTO or a SR swapped coupe lol
@hcr32love 400whp NEO R32 Sedan |
boost, drifty, dynamometer, smoke, spin |
