1995 NISSAN 240sx KOUKI LS1 SWAP CAGED
Best s14 i have ever owned
Don't really have to get rid of but I got a new build I'm working on so just seeing what's offered. I have put a lot of time and money into this car. For sale or may trade. 1995 Nissan 240sx (low miles on chassis) Kouki front end Fiberglass front wide body fenders Black housing headlights Vented Carbon fiber hood Zenki bumper with front lip Oem Kouki side skirts LED tail lights Rocket bunny rear trunk wing Roof wing Aqua marine firemist paint Ls1 engine 95k miles Slide Motorsports mount kit with new motor mounts Custom headers and 3" exhaust Canton racing oil pan Melling high volume/pressure oil pump Oil filter relocation kit with braided lines 3" intake with hks filter Reprogrammed PCM T56 6 speed new synchros and upgraded steel 3-4 fork ACT 6 puck unsprung clutch Custom 1 piece steel driveshaft Polyurethane trans mount Stainless steel braided line New slave cylinder Slide Motorsports shift knob PBM comp coilovers Adjustable tension rods Custom extended adjustable front lower control arms with 3/4 hiem joints Custom modded high angle knuckle kit Custom adjustable hiem joint tie rod ends PBM solid rack eccentric bushings Tie rods rack spacers Solid mount diff Plate welded diff PBM solid subframe risers Emusa Adjustable ruca, toe rods, and traction rods Drilled slotted rotors Custom dual rear caliper set up uses stock caliper and wilwood dual piston caliper for hydro 5 lug hubs Touge factory extended studs Custom full tube front Custom front and rear bash bar bumpers Full cage with boxed mounts and dimple die pillar braces Custom tubed dash as part of cage Digital gauges oil pressure, water temp, Oil temp, fuel level and tach Power windows Battery kill switch Bride rep racing seats Takata racing harnesses Custom hydro ebrake Painted deep dish wood steering wheel Plastic 14 gallon Fuel cell Walbro 255lph inline pump Battery relocation to trunk Sard adjustable fuel pressure regulator with fuel pressure gauge mounted on rail Aluminum dual core radiator 2 - 12" electric fans Power steering cooler Braided high pressure steering line D1 spec overflow bottle con has battle wounds Car runs and drifts awesome. It doesn't have things like a/c, heat, windshield wipers, turn signals, sound deadening, carpet , etc. Does have power windows still, power steering, Power brakes, brake lights, headlights, etc. TRADES ARE WELCOME BUT NO HONDA UNLESS ITS S2000 with extremely low miles 370z, supra, skyline, s15, evo , sti 350z with alot cash on your end you get the picture. i dont want your junk that you cant sell or bikes and especially not FWD you dont have the cash dont text me, you want a free joyride, dont text me. have the money upfront. im just testing the waters at the moment cause i dont mind keeping this car at all. This car is a clean title with low miles even on the chassis. 404 two71 490six $15,000 OBO ![]() ![]() ![]() ![]() ![]() |
