Old 03-18-2016, 08:05 AM   #1
USAFs13
USAFs13 is an unknown quantity at this point
s14 S14 Door locks
Just want to make sure I'm not missing something easy before I have it professionally repaired. My driver side door locks fine but my passenger side door seems to not catch when I try to lock it.
A while back the door was locked and wouldnt come unlocked until I pulled the panel off. Since then the door just won't lock. I can press the lock from the inside and it appears to be locked but opens right up.
I just reprogrammed a new remote to the factory security setup and when I press the lock button they both move but the lock on the passenger side still does not engage.
USAFs13 is offline   Reply With Quote
Old 03-18-2016, 02:05 PM   #2
cotbu
cotbu's Avatar
The actuator is working from your description, so it must be the linkage.
Pull the panel back off and look.[emoji29]
Sent from my LG-H345 using Tapatalk
Old 03-18-2016, 04:27 PM   #3
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
After 21 years of use, they probably need greasing or something.
SoundEfx is offline   Reply With Quote
Old 03-18-2016, 05:26 PM   #4
Rob's S14
Rob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfection
Send a message via AIM to Rob's S14
i know s13's had a habit of not working(locking) unless you were holding the latch open from the outside when you closed the door. might work at least until you get the lock fixed.
Rob's S14 is offline   Reply With Quote
Old 03-18-2016, 06:05 PM   #5
S14kouki805
S14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud of
Mine has the exact problem, chiming in for the fix
S14kouki805 is offline   Reply With Quote
