Old 03-20-2016, 12:43 PM   #1
TonyTunes
TonyTunes's Avatar
TonyTunes is a well-known jackass
Volt problem???
Anytime I drive at night with my lights on if I press the brake my rpms drop and soon as I let off they jump back up. This happens when anything electrical is used. example- open door, seatbelt moves, rpms drop, lights dim... Literally anything that involves using power makes the car drop rpms and dim. Battery? Bad ground?
IG- @TonyTunes
TonyTunes is offline   Reply With Quote
Old 03-20-2016, 07:04 PM   #2
jedi03
Try Cleanin grounds first and also put your battery on the tester. ..
Old 03-20-2016, 07:15 PM   #3
TonyTunes
TonyTunes's Avatar
I was thinking about beefing up the ground system. Should I just do 1 from battery to chassis than another one from chassis to engine? Thicker the better, correct?
IG- @TonyTunes
Old 03-20-2016, 08:58 PM   #4
jedi03
Usually.. the ground kits aren't bad...I have a relocated battery so it's almost a must...I usually do both sides of the head to strut towers...the intake mani close to the alternator to frame rail and battery to body
