Old 03-26-2016, 08:41 AM   #1
robvierhout
robvierhout is an unknown quantity at this point
S14 Autocross Suspension Geometry??
I've been searching for a thread with people sharing what geometries they are running for a race application; all I could find was for low-low's or drift.
I know the Hoosier A7's require -2.5 degrees camber.
I have an S14, Megan track coilovers, Megan rear adjustable control arms, P2M front adjustable lower control arms, Tein tie rods.
Could anyone give some direction or advice on the proper suspension geometry for autocross?
robvierhout is offline   Reply With Quote
Old 03-26-2016, 09:11 AM   #2
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Alignment specs and geometry are a bit different. . Youll want more camber than that for the front. Geberally people run at lest 3 degrees in front, zero toe or maybe a touch of toe out, and 7ish degrees of caster.
For the back, 1.5ish degrees if camber, 1/8 toe in or so, and thats a decent place to start.
Really getting some good shocks and a good diff will make quite a significant improvement for autox.
Nissanroadracing.com is where you should be looking for info.
Old 03-26-2016, 09:20 AM   #3
robvierhout
very helpful. thank you!
Old 03-28-2016, 09:26 AM   #4
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
Ive been looking into this also,
Ive got roll center correction shanks in front,
Subframe risers in rear for roll center correction,
bump steer correction tie rods,
Plus appropriate alignment specs. Havent drove yet :/
Jorgs_7 is offline   Reply With Quote
autocross, suspension geometry, suspension setup
