Old 03-31-2016, 04:15 PM   #1
jlmillionaire
jlmillionaire's Avatar
jlmillionaire is an unknown quantity at this point
Post head removal inspection
Hey guys I took off my head today , noticed some nicks on piston#2 and#3 I'm going to post pics 1 thru 4 let me know what you guys think?
jlmillionaire is offline   Reply With Quote
Old 03-31-2016, 04:30 PM   #2
Kylepaschke
Kylepaschke is an unknown quantity at this point
aftermarket valvetrain?
Kylepaschke is offline   Reply With Quote
Old 03-31-2016, 04:46 PM   #3
jlmillionaire
No I believe every thing is stock besides cam gears
Old 03-31-2016, 04:31 PM   #4
KAT-PWR
KAT-PWR's Avatar
Lol valve contact
MRP Manufacturing
Old 03-31-2016, 04:47 PM   #5
jlmillionaire
Will I be fine to use them how they are or doi have major problems
Old 03-31-2016, 04:51 PM   #6
KAT-PWR
KAT-PWR's Avatar
Probably need to adjust the cam gears. This is why cam gears are pointless unless you know what you're doing.
MRP Manufacturing
Old 03-31-2016, 05:03 PM   #7
thegr8one013
thegr8one013 is an unknown quantity at this point
you definitely need to adjust the cam gears. if the motor is completely stock, put stock cam gears back on.
if i were you i would i double check the head by pouring gasoline in the ports and make sure the valves are still sealing
thegr8one013 is offline   Reply With Quote
Old 03-31-2016, 06:37 PM   #8
cotbu
cotbu's Avatar
They all have made contact with the valves, check valves as well. If you did any shimming? Redo or undo! cam gears, do you really need them? If you do learn how to degree.
Old 04-01-2016, 09:47 AM   #9
jlmillionaire
I didn't do any shimming, adjustable cam gears are set close to stock I'm going to post photo below . I'm going to upgrade to hks step 2 with hks springs retainers. Should I ditch the adjustable cam gears and go back to vct?
Old 04-01-2016, 01:45 PM   #10
cotbu
cotbu's Avatar
So one will tell you what to do for sure.
Its really up to you! Just know this close is not good enough!
Old 04-01-2016, 04:59 PM   #11
jlmillionaire
Are you referring to how the cam gears are set, when you say close is not good enough
Old 04-01-2016, 05:29 PM   #12
jlmillionaire
Btw my head and Pistons look really clean I must have a low milage motor
Old 04-01-2016, 06:33 PM   #13
Darkcr3w
Darkcr3w is an unknown quantity at this point
Set your engine up to top dead center
Darkcr3w is offline   Reply With Quote
Old 04-01-2016, 06:41 PM   #14
jlmillionaire
It is on cylinder 1
Old 04-29-2016, 06:06 PM   #15
jlmillionaire
I just removed my rocker arms and discovered this
Old 04-29-2016, 06:44 PM   #16
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Sheesh......
Old 04-29-2016, 06:47 PM   #17
jlmillionaire
Really it's that bad??? Engine ran great before I decided to rip it apart
Old 04-30-2016, 06:51 PM   #18
jlmillionaire
Well I'm going to get the head decked anyways so I will see what my machine guy says , I really hope I can use this head knowing that I just got hks step 2 system
Old 04-30-2016, 08:29 PM   #19
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
I'd check the valves too. Looks like a rocker exploded in there and someone rebuilt it. Maybe the valve contact is old news, but either way if you don't need the adjustability of the cam gears there is no sense in having them other than to say that you have them.
zombiewolf513 is offline   Reply With Quote
Old 04-30-2016, 09:02 PM   #20
jlmillionaire
Yea I'm going back to stock cam gears need to source them , I'll probably be good to go with this head tho
Old 04-30-2016, 10:57 PM   #21
rawgarage
Trader Rating: (75)
i have stock cam gears....
Old 05-01-2016, 12:18 AM   #22
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
I have a stock s14 SR VCT gear here too.
mewantkouki is offline   Reply With Quote
Old 05-01-2016, 08:12 AM   #23
jlmillionaire
Ok cool I'll let you guys know thanks!!!
Old 05-01-2016, 09:25 AM   #24
Kelgarageperformance
Kelgarageperformance is an unknown quantity at this point
Need help my Sr 20 car died wild running bad starter I change it now my car wount start j have no check ingine light
Kelgarageperformance is offline   Reply With Quote
Old 05-01-2016, 09:58 AM   #25
jlmillionaire
You should of got the starter bench checked , and make sure you aligned the teeth on the flywheel
Old 05-01-2016, 01:11 PM   #26
zombiewolf513
Sweet threadjack.
Use the small questions thread
Old 05-01-2016, 09:51 AM   #27
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
27 and don't know how to use a forum?
Please apologize and run youngling, RUN!!!!
SoundEfx is offline   Reply With Quote
Old 05-01-2016, 04:21 PM   #28
The car cranks no start ,but I have no ingine light when key it's on the on position
Old 05-01-2016, 04:25 PM   #29
I don't think it's the ecu because I have a power fc the comes on
Old 05-01-2016, 06:57 PM   #30
Mcflurry
Mcflurry's Avatar
Mcflurry is an unknown quantity at this point
I'm not sure why people are telling you to put the stock cam gears back on when you could either set the gears yourself or ask a member to help you out with it. Would seem far cheaper to just adjust the gears.
Mcflurry is offline   Reply With Quote
