Old 04-22-2016, 01:40 PM   #1
Sgtnubcakes
Sgtnubcakes is an unknown quantity at this point
s13 91 s13 Clean Title current tags
Asking 2500
COME PICK IT UP TODAY OR TOMRROW!
Throwing in all my extra parts:
s13 KA head (Needs decked) has cams and valve cover
s13 ka front cover upper and lower
extra ka oil pan
s13 ka crank shaft with gradle
s14 intake manifold missing a fuel rail
s13 MAFs (2)
1991 s13 Hatchback se with an '95 s14 KA
200k on odometer (Don't know if it's the original one)
105k on motor
5 speed (Was auto, but previous owner did the conversion)
Pros:
NRG bucket seats
NRG short hub
NRG Quick release deep dish steering wheel W/ Lock
Auto meter gauges:
Water
Volts
Oil pressure
Will toss in Boost Gauge also
Power windows
manual sunroof
Drilled / Slotted rotors
extra set of s13 SE Rims with BRAND NEW Falken tires
Cold air intake
CX Racing Aluminum Radiator w/ slim electrical fans on a switch
unknown headers w/ straight pipe
New intake manifold gaskets (Has s13 manifold)
New valve cover gaskets
Removed timing chain plastic guide
new spark plugs
new Cometic 0 Multi Layer Steel Exhaust Manifold Gasket
lighten flywheel (Unknown brand)
S14 Seat belts (Driver side installed but needs buckle)
Polyurethane bushings throughout the whole car
new ball front/rear LCA ball joints installed
Tein lowering springs
Going this weekend to get smog / pay this year (2016-2017) registration fees
Clean Title
Cons:
Cracked dash
One color except roof / trunk
Some damage from previous owner
needs an alignment
Needs "help" passing smog
Has bald tires on the car right now
Needs cage to install 4 point seat belts (NRG 3" 4 points for driver / passenger will be included)
Only lap belt is installed for 4 point harness
Passenger side s14 seat belt needs hardware / buckle
Both driver and passenger bucket seats are unadjustable
No interior installed but have some parts that will be included
Stripped interior except dash
Sunroof handle is broken
will update with any info that I missed
I Work from 9-5 live in the rialto / fontana area.
Text would be the best way to get ahold of me
(909) 278-7327 -David
Sgtnubcakes is offline   Reply With Quote
hatchback, s13
