Old 05-16-2016, 04:52 PM   #1
ppark
ppark is a glorious beacon of lightppark is a glorious beacon of lightppark is a glorious beacon of lightppark is a glorious beacon of lightppark is a glorious beacon of lightppark is a glorious beacon of lightppark is a glorious beacon of lightppark is a glorious beacon of lightppark is a glorious beacon of lightppark is a glorious beacon of lightppark is a glorious beacon of light
PBM comp fitment question. 18x9.5+22
Quick question for those running Pbm comps on their s13!
Im just put on my wheels in the front that are 18x9.5+22, and i am having issues with the wheels rubbing on the suspension.
What size spacer are you guys running with this same setup?
ppark is offline   Reply With Quote
Old 05-16-2016, 05:02 PM   #2
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
you probably only need a slip on 3mm spacer to clear the spring
Old 05-16-2016, 05:23 PM   #3
ppark
thats what is confusing me, i have a 7mm spacer on there right now and still rubbing a bit.
Just ordered 15mm hubcentric spacers they should do the trick.
Still curious though if anyone else has an issue with rubbing on pbm comps with the same wheels specs
Old 05-16-2016, 06:37 PM   #4
O$mo
O$mo's Avatar
O$mo is an unknown quantity at this point
yeah i had the same problem on my s14 just used a 5mm slip on and i was good and im running 18x9.5 +12 all around
O$mo is offline   Reply With Quote
Old 05-16-2016, 07:52 PM   #5
theStig880
theStig880's Avatar
theStig880 is on a distinguished road
I had 17x9.5 +22 (so same issue with rubbing) with my PBM Comps and I used one of those cheap ass autozone spacers. Pretty sure it was 5mm? Maybe 7 but they were pretty thin.
Follow me on Instagram or don't @cason880
theStig880 is offline   Reply With Quote
Old 05-17-2016, 12:36 AM   #6
ppark
okay thanks for the info guys!
15 mm should be perfect from what you guys have told me, im using a 5mm slip on right now and its not enough. after the 15mm spacer i should drop down to +7 offset and be good to go.
Old 05-17-2016, 08:18 AM   #7
Gingersmurf
Gingersmurf is an unknown quantity at this point
I have the same set up on my S13. PBM Comp's with a 17x9.5 +22 wheel. i used a 8mm spacer but found it rubbed under compression, and moved to a 10mm spacer. That was the trick with my car. You should also look into different tires, as each has a different bend to the side wall, my original set of tires bowed outwards causing rubbing too.
KAs are like Frank's RedHot, Nissan put that shit in everything
Gingersmurf is offline   Reply With Quote
Old 05-17-2016, 05:13 PM   #8
Bushido
Bushido's Avatar
18x9.5+15 is minimum clearance with PBM
